AllowLongSymbolNames 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 549| 评论: 0|原作者: admin|来自: AutoCAD
确定符号名称是否可以包含扩展字符集或超过 31 个字符。
object.AllowLongSymbolNames
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:使用扩展符号名称。
  • False:使用受限的符号名称。
此属性的初始值为 。True
扩展符号名称最多可以包含 255 个字符和 A-Z、0-9、空格以及 Microsoft Windows 和 AutoCAD 未用于其他目的的任何特殊字符。
受限制的符号名称最多可以包含 31 个字符和 A-Z、0-9、美元符号 ($)、下划线 (_) 和连字符 (-)。
此属性适用于存储在符号表中的非图形对象(如线型和图层)的名称。
注意:此属性的值存储在 EXTNAMES 系统变量中。
Sub Example_AllowLongSymbolNames()
    ' This example reads and modifies the preference value that controls
    ' whether symbol names include extended character sets or more
    ' than 31 characters.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.AllowLongSymbolNames
    MsgBox "The AllowLongSymbolNames preference is set to: " & originalValue
    ' Modify the AllowLongSymbolNames preference by toggling the value
    ACADPref.AllowLongSymbolNames = Not (ACADPref.AllowLongSymbolNames)
    newValue = ACADPref.AllowLongSymbolNames
    MsgBox "The AllowLongSymbolNames preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AllowLongSymbolNames = originalValue
    MsgBox "The AllowLongSymbolNames preference was reset back to: " & originalValue
(defun c:Example_AllowLongSymbolNames()
    ;; This example reads and modifies the preference value that controls
    ;; whether symbol names include extended character sets or more
    ;; than 31 characters.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Preferences doc))
    (setq originalValue (vla-get-AllowLongSymbolNames ACADPref))
    (alert (strcat "The AllowLongSymbolNames preference is set to: " (if (= originalValue :vlax-true) "1" "0")))
    ;; Modify the AllowLongSymbolNames preference by toggling the value
    (vla-put-AllowLongSymbolNames ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AllowLongSymbolNames ACADPref))
    (alert (strcat "The AllowLongSymbolNames preference has been set to: " (if (= newValue :vlax-true) "1" "0")))
    ;;         this preference in effect
    (vla-put-AllowLongSymbolNames ACADPref originalValue)
    (alert (strcat "The AllowLongSymbolNames preference was reset back to: " (if (= originalValue :vlax-true) "1" "0")))
GMT+8, 2026-10-17 20:59
