Alignment 属性 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 750| 评论: 0|原作者: admin|来自: AutoCAD
指定属性、属性参照或文本的垂直和水平对齐方式。
object.Alignment
类型:属性AttributeRef文本
此属性应用于的对象。
只读:
类型:枚举acAlignment
  • acAlignmentLeft
  • acAlignmentCenter
  • acAlignmentRight
  • acAlignmentAligned
  • acAlignmentMiddle
  • acAlignmentFit
  • acAlignmentTopLeft
  • acAlignmentTopCenter
  • acAlignmentTopRight
  • acAlignmentMiddleLeft
  • acAlignmentMiddleCenter
  • acAlignmentMiddleRight
  • acAlignmentBottomLeft
  • acAlignmentBottomCenter
  • acAlignmentBottomRight
对齐的文本使用属性来定位文本。acAlignmentLeftInsertionPoint
与 和 属性对齐或同时使用 和 属性来定位文本的文本。acAlignmentAlignedacAlignmentFitInsertionPointTextAlignmentPoint
与任何其他位置对齐的文本使用该属性来定位文本。TextAlignmentPoint
Sub Example_Alignment()
   ' This example creates a text object in model space and
   ' demonstrates setting the alignment of the new text string
    Dim textObj As AcadText
    Dim textString As String
    Dim insertionPoint(0 To 2) As Double, alignmentPoint(0 To 2) As Double
    Dim height As Double
    Dim oldPDMODE As Integer
    Dim pointObj As AcadPoint
    ' Define the new Text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    alignmentPoint(0) = 3: alignmentPoint(1) = 3: alignmentPoint(2) = 0
    height = 0.5
    ' Create the Text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    oldPDMODE = ThisDrawing.GetVariable("PDMODE")   ' Record existing point style
    ' Create a crosshair over the text alignment point
    ' to better visualize the alignment process
    Set pointObj = ThisDrawing.ModelSpace.AddPoint(alignmentPoint)
    ThisDrawing.SetVariable "PDMODE", 2             ' Set point style to crosshair
    ' Set the text alignment to a value other than acAlignmentLeft, which is the default.
    ' Create a point that will act as an alignment reference point
    textObj.Alignment = acAlignmentRight
    ' Create the text alignment reference point and the text will automatically
    ' align to the right of this point, because the text
    ' alignment was set to acAlignmentRight
    textObj.TextAlignmentPoint = alignmentPoint
    ThisDrawing.Regen acActiveViewport
    MsgBox "The Text object is now aligned to the right of the alignment point"
    ' Center the text to the alignment point
    textObj.Alignment = acAlignmentCenter
    MsgBox "The Text object is now centered to the alignment point"
    ' Reset point style
    ThisDrawing.SetVariable "PDMODE", oldPDMODE
(defun c:Example_Alignment()
   ;; This example creates a text object in model space and
   ;; demonstrates setting the alignment of the new text string
    ;; Define the new Text object
    (setq insertionPoint (vlax-3d-point 3 3 0)
          alignmentPoint (vlax-3d-point 3 3 0)
          textString "Hello, World."
          height 0.5)
    ;; Create the Text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (setq oldPDMODE (vlax-variant-value (vla-GetVariable doc "PDMODE")))   ;; Record existing point style
    ;; Create a crosshair over the text alignment point
    ;; to better visualize the alignment process
    (setq pointObj (vla-AddPoint modelSpace alignmentPoint))
    (vla-SetVariable doc "PDMODE" 2)             ;; Set point style to crosshair
    (vla-ZoomAll acadObj)
    ;; Set the text alignment to a value other than acAlignmentLeft, which is the default.
    ;; Create a point that will act as an alignment reference point
    (vla-put-Alignment textObj acAlignmentRight)
    ;; Create the text alignment reference point and the text will automatically
    ;; align to the right of this point, because the text
    ;; alignment was set to acAlignmentRight
    (vla-put-TextAlignmentPoint textObj alignmentPoint)
    (vla-Regen doc acActiveViewport)
    (alert "The Text object is now aligned to the right of the alignment point.")
    ;; Center the text to the alignment point
    (vla-put-Alignment textObj acAlignmentCenter)
    (alert "The Text object is now centered to the alignment point.")
    ;; Reset point style
    (vla-SetVariable doc "PDMODE" oldPDMODE)
GMT+8, 2026-9-13 00:45
