Unload 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 769| 评论: 0|原作者: admin|来自: AutoCAD
Unload 方法 (ActiveX)
卸载菜单组或外部参照。
object.Unload
类型:ExternalReference、MenuGroup
此方法应用到的对象。
返回值 (RetVal)
无返回值。
ExternalReference:从图形中卸载对象 (xref) 时,图形打开速度更快,占用的内存更少。未加载的外部参照不显示,并且与外部参照相关的符号表信息不会出现在绘图中。但是,可以通过使用该方法重新加载外部参照来恢复所有信息。ExternalReferenceReload
要卸载外部参照,必须卸载定义外部参照的模块。例如,以下 VBA 代码行卸载存储在变量中的外部引用:xrefInserted
ThisDrawing.Blocks.Item(xrefInserted.name).Unload
MenuGroup:从图形中卸载菜单组时,对该组内菜单和工具栏的任何引用都将失效。在卸载菜单组之前,请始终删除或设置对要卸载的菜单组中的工具栏和菜单的任何引用。NULL
Sub Example_Unload()
    On Error GoTo ERRORHANDLER
    ' Define external reference to be inserted
    Dim xrefHome As AcadBlock
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    Dim PathName As String
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "c:/AutoCAD/sample/City map.dwg"
    ' Add the external reference
    Set xrefInserted = ThisDrawing.ModelSpace. _
            AttachExternalReference(PathName, "XREF_IMAGE", _
            insertionPnt, 1, 1, 1, 0, False)
    ZoomAll
    MsgBox "The external reference is attached."
    ' Unload the external reference definition
    MsgBox "The external reference is unloaded."
    Exit Sub
ERRORHANDLER:
    MsgBox Err.Description
(defun c:Example_Unload()
    ;; Define external reference to be inserted
    (setq insertionPnt (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external reference to the block
    (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (alert "The external reference is attached.")
    ;; Unload the external reference definition
    (vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (vla-Regen doc :vlax-true)
    (alert "The external reference is unloaded.")
    ;; Reload the external reference definition
    (vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (alert "The external reference is reloaded.")
GMT+8, 2026-10-17 23:00
