SetDatabase 方法 (ActiveX)
将 AutoCAD 数据库与 LayerStateManager 对象相关联。 支持的平台:仅限 Windows 签名VBA: object.SetDatabase Database
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_SetDatabase()
' The following code saves the color and linetype settings
' of the current layer. It uses the SetDatabase method to
' associate the current drawing database with the
' LayerStateManager object.
Dim oLSM As AcadLayerStateManager
' Access the LayerStateManager object
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
' Associate the current drawing database with LayerStateManager
oLSM.SetDatabase ThisDrawing.Database
oLSM.Save "ColorLinetype", acLsColor + acLsLineType
可视化 LISP: (defun c:Example_SetDatabase()
;; The following code saves the color and linetype settings
;; of the current layer. It uses the SetDatabase method to
;; associate the current drawing database with the
;; LayerStateManager object.
;; Access the LayerStateManager object
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
;; Associate the current drawing database with LayerStateManager
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
GMT+8, 2026-11-25 15:30
