SetCellClass 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 721| 评论: 0|原作者: admin|来自: AutoCAD
设置单元格样式的类。
object.SetCellClass StringCellStyle, cellClass
类型:TableStyle
此方法应用到的对象。
StringCellStyle
访问:仅输入
类型:字符串
单元格样式名称。
cellClass
访问:仅输入
类型:整数
单元格样式类。
返回值 (RetVal)
无返回值。
Sub Example_CellClass()
    ' the style classes and formatting.
    Dim dictObj As AcadDictionary
    ' Create the custom TableStyle object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As IAcadTableStyle
    keyName = "NewStyle"
    className = "AcDbTableStyle"
    Set customObj = dictObj.AddObject(keyName, className)
    customObj.Name = "NewStyle"
    customObj.Description = "New Style for My Tables"
    customObj.CreateCellStyle ("NewTestStyle")
    Dim cellTestFormat As String
    customObj.SetCellClass "NewTestStyle", 4
    customObj.SetRotation "NewTestStyle", 8.4
    MsgBox "The cell class is " & customObj.GetCellClass("NewTestStyle") & _
           " the cell rotation is " & customObj.GetRotation("NewTestStyle")
(defun c:Example_CellClass()
    ;; the style classes and formatting.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Create the custom TableStyle object in the dictionary
    (setq keyName "NewStyle"
          className "AcDbTableStyle")
    (setq customObj (vla-AddObject dictObj keyName className))
    (vla-put-Name customObj "NewStyle")
    (vla-put-Description customObj "New Style for My Tables")
    (vla-CreateCellStyle customObj "NewTestStyle")
    (vla-SetCellClass customObj "NewTestStyle" 4)
    (vla-SetRotation customObj "NewTestStyle" 8.4)
    (alert (strcat "The cell class is " (itoa (vla-GetCellClass customObj "NewTestStyle"))
                   " and the cell rotation is " (rtos (vla-GetRotation customObj "NewTestStyle") 2) "."
GMT+8, 2026-10-17 05:10
