SelectAtPoint 方法 (ActiveX)
选取通过给定点的对象并将其放入选择集中。 支持的平台:仅限 Windows 签名VBA: object.SelectAtPoint Point, FilterType, FilterData
返回值 (RetVal)无返回值。 言论此方法支持过滤机制。 PICKBOX 系统变量会影响对象选择。 有关更多选择模式选项,请参见 、 和 方法。SelectSelectByPolygonSelectOnScreen 例子VBA: Sub Example_SelectAtPoint()
' This example adds objects to a selection set by identifying a point.
' At first all objects at the point are added to the selection set. Then
' only circle objects at the point are added to the selection set.
' Create the selection set
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET1")
' Add to the selection set all the objects that lie at point(6.8,9.4,0)
Dim point(0 To 2) As Double
point(0) = 6.8: point(1) = 9.4: point(2) = 0
ssetObj.SelectAtPoint point
' Add to the selection set all the Circles that lie at point (6.8,9.4,0)
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
gpCode(0) = 0
dataValue(0) = "Circle"
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ssetObj.SelectAtPoint point, groupCode, dataCode
可视化 LISP: (vl-load-com)
(defun c:Example_SelectAtPoint()
;; This example adds objects to a selection set by identifying a point.
;; At first all objects at the point are added to the selection set. Then
;; only circle objects at the point are added to the selection set.
;; Create the selection set
(setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SSET1"))
;; Add to the selection set all the objects that lie at point(6.8,9.4,0)
(setq point (vlax-3d-point 6.8 9.4 0))
(vla-SelectAtPoint ssetObj point)
(alert (strcat "Objects selected: " (itoa (vla-get-Count ssetObj))))
(vla-Clear ssetObj)
;; Add to the selection set all the Circles that lie at point (6.8,9.4,0)
(setq gpCode (vlax-make-safearray vlax-vbInteger '(0 . 0)))
(vlax-safearray-put-element gpCode 0 0)
(setq dataValue (vlax-make-safearray vlax-vbVariant '(0 . 0)))
(vlax-safearray-put-element dataValue 0 "Circle")
(vla-SelectAtPoint ssetObj point gpCode dataValue)
(vla-Delete ssetObj)
GMT+8, 2026-11-30 11:02
