ScaleEntity 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 985| 评论: 0|原作者: admin|来自: AutoCAD
在 X、Y 和 Z 方向上平均缩放对象。
object.ScaleEntity BasePoint, ScaleFactor
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
基点
访问:仅输入
类型:变体(双打的三元素阵列)
指定基点的 3D WCS 坐标。
比例因子
访问:仅输入
类型:双
缩放对象所依据的因子。对象的尺寸乘以比例因子。大于 1 的比例因子将放大对象。介于 0 和 1 之间的比例因子会减少对象。比例因子必须大于 0.0。
返回值 (RetVal)
无返回值。
ScaleFactor = 0.5 和 ScaleFactor = 2
Sub Example_ScaleEntity()
    ' This example creates a lightweight polyline
    ' and then scales that polyline.
    ' Create the polyline
    Dim points(0 To 11) As Double
    points(0) = 1: points(1) = 2
    points(2) = 1: points(3) = 3
    points(4) = 2: points(5) = 3
    points(6) = 3: points(7) = 3
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 2
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
    ZoomAll
    MsgBox "Scale the polyline by 0.5", , "ScaleEntity Example"
    ' Define the scale
    Dim basePoint(0 To 2) As Double
    Dim scalefactor As Double
    basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
    scalefactor = 0.5
    ' Scale the polyline
    plineObj.ScaleEntity basePoint, scalefactor
    ZoomAll
    MsgBox "Scale completed.", , "ScaleEntity Example"
(defun c:Example_ScaleEntity()
    ;; This example creates a lightweight polyline
    ;; and then scales that polyline.
    ;; Create the polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill points '(1 2
                                  1 3
                                  2 3
                                  3 3
                                  4 4
                                  4 2
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-put-Closed plineObj :vlax-true)
    (vla-ZoomAll acadObj)
    (alert "Scale the polyline by 0.5")
    ;; Define the scale
    (setq basePoint (vlax-3d-point 4 4.25 0)
          scalefactor 0.5)
    ;; Scale the polyline
    (vla-ScaleEntity plineObj basePoint scalefactor)
    (alert "Scale completed.")
GMT+8, 2026-11-29 11:10
