RenameCellStyle 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 786| 评论: 0|原作者: admin|来自: AutoCAD
重命名单元格样式。
object.RenameCellStyle StringOldName, StringNewName
类型:TableStyle
此方法应用到的对象。
StringOldName
访问:仅输入
类型:字符串
旧单元格样式名称。
字符串新名称
访问:仅输入
类型:字符串
新的单元格样式名称。
返回值 (RetVal)
无返回值。
Sub Example_CellStyle()
    ' the style name and formatting.
    Dim dictObj As AcadDictionary
    ' Create the custom TableStyle object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As IAcadTableStyle
    keyName = "NewStyle"
    className = "AcDbTableStyle"
    Set customObj = dictObj.AddObject(keyName, className)
    customObj.Name = "NewStyle"
    customObj.Description = "New Style for My Tables"
    customObj.CreateCellStyle ("NewTestStyle")
    Dim cellTestFormat As String
    customObj.SetFormat2 "NewTestStyle", "test format"
    customObj.GetFormat2 "NewTestStyle", cellTestFormat
    MsgBox "Cell Style Name = " & cellTestFormat
    customObj.RenameCellStyle "NewTestStyle", "NewTestStyle2"
    customObj.GetFormat2 "NewTestStyle2", cellTestFormat
    Dim uniqueStyleName As String
    uniqueStyleName = customObj.GetUniqueCellStyleName("testbase")
    MsgBox "Cell Style Name = " & uniqueStyleName
    If customObj.GetIsCellStyleInUse("testbase") = False Then
        MsgBox "That cell style is not being used!"
    End If
    customObj.CreateCellStyleFromStyle "TestStyleFromStyle", "NewTestStyle2"
    customObj.DeleteCellStyle "NewTestStyle2"
    Dim numOfStyles As Long
    numOfStyles = customObj.NumCellStyles
(defun c:Example_CellStyle()
    ;; the style name and formatting.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Create the custom TableStyle object in the dictionary
    (setq keyName "NewStyle"
          className "AcDbTableStyle")
    (setq customObj (vla-AddObject dictObj keyName className))
    (vla-put-Name customObj "NewStyle")
    (vla-put-Description customObj "New Style for My Tables")
    (vla-CreateCellStyle customObj "NewTestStyle")
    (setq cellTestFormat "")
    (vla-SetFormat2 customObj "NewTestStyle" "test format")
    (vla-GetFormat2 customObj "NewTestStyle" 'cellTestFormat)
    (alert (strcat "Cell Style Name = " cellTestFormat))
    (vla-RenameCellStyle customObj "NewTestStyle" "NewTestStyle2")
    (vla-GetFormat2 customObj "NewTestStyle2" 'cellTestFormat)
    (setq uniqueStyleName (vla-GetUniqueCellStyleName customObj "testbase"))
    (alert (strcat "Cell Style Name = " uniqueStyleName))
    (if (= (vla-GetIsCellStyleInUse customObj "testbase") :vlax-false)
        (alert "That cell style is not being used!")
    (vla-CreateCellStyleFromStyle customObj "TestStyleFromStyle" "NewTestStyle2")
    (vla-DeleteCellStyle customObj "NewTestStyle2")
    (setq numOfStyles (vla-get-NumCellStyles customObj))
    (alert (strcat "Number of Cell Styles = " (itoa numOfStyles)))
GMT+8, 2026-11-29 11:03
