Rename 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 765| 评论: 0|原作者: admin|来自: AutoCAD
Rename 方法 (ActiveX)
重命名字典中的项目或一组已保存的图层设置。
object.Rename OldName, NewName
类型:字典、LayerStateManager
此方法应用到的对象。
旧名称
访问:仅输入
类型:字符串
字典中对象的当前名称(关键字),或一组已保存图层设置的名称。
新名称
访问:仅输入
类型:字符串
字典中对象的新名称(关键字)或已保存图层设置的新名称。
返回值 (RetVal)
无返回值。
Sub Example_Rename()
    ' This example creates a dictionary and adds
    ' a custom object to that dictionary. It then
    ' renames the object in the dictionary.
    Dim dictObj As AcadDictionary
    Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
    ' Load the ObjectARX application that defines the custom object.
    ' Note: The application listed here does not exist and
    ' will cause an error when run. Change the application name
    ' to the path and name of your ObjectARX application.
    ThisDrawing.Application.LoadArx "MyARXApp.dll"
    ' Create the custom object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As AcadObject
    keyName = "OBJ1"
    className = "CAsdkDictObject"
    Set customObj = dictObj.AddObject(keyName, className)
    ' Rename the object
    dictObj.Rename keyName, "NewKeyName"
Public Sub Example_RenameLayerSettings()
    ' This example renames a set of saved layer settings from
    ' "ColorLinetype" to "OldColorLinetype."
    Dim oLSM As AcadLayerStateManager
    ' Access the LayerStateManager object.
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
    ' Associate the current drawing database with the
    ' LayerStateManager object.
    oLSM.SetDatabase ThisDrawing.Database
    ' Rename the saved layer settings.
    oLSM.Rename "ColorLinetype", "OldColorLinetype"
(defun c:Example_Rename()
    ;; This example creates a dictionary and adds
    ;; a custom object to that dictionary. It then
    ;; renames the object in the dictionary.
    (setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
    ;; Load the ObjectARX application that defines the custom object.
    ;; Note: The application listed here does not exist and
    ;; will cause an error when run. Change the application name
    ;; to the path and name of your ObjectARX application.
    (vla-LoadArx acadObj "MyARXApp.dll")
    ;; Create the custom object in the dictionary
    (setq keyName "OBJ1")
    (setq className "CAsdkDictObject")
    (setq customObj (vla-AddObject dictObj keyName className))
    ;; Rename the object
    (vla-Rename dictObj keyName "NewKeyName")
(defun c:Example_RenameLayerSettings()
    ;; This example renames a set of saved layer settings from
    ;; "ColorLinetype" to "OldColorLinetype."
    ;; Access the LayerStateManager object.
    (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
    ;; Associate the current drawing database with the
    ;; LayerStateManager object.
    (vla-SetDatabase oLSM (vla-get-Database doc))
    (vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
    ;; Rename the saved layer settings.
    (vla-Rename oLSM "ColorLinetype" "OldColorLinetype")
GMT+8, 2026-10-27 11:13
