RemoveItems 方法 (ActiveX)
从组或选择集中删除指定项目。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论从组或选择集中移除的项目将保留在图形中;它们不再与组或选择集相关联。此功能模拟该方法中的功能,只不过允许您指定要删除的单个项,而不是整个选择集。ClearRemoveItems 此方法与 and 方法的不同之处在于它不会从图形中删除对象。DeleteErase 例子VBA: Sub Example_RemoveItems()
' This example creates a selection set and several objects.
' It adds the objects to the selection set, and then
' removes two of the objects from the selection set.
' Create the new selection set
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SELECTIONSET")
' Create a Ray object in model space
Dim rayObj As AcadRay
Dim basePoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
' Create a polyline object in model space
Dim points(0 To 5) As Double
points(0) = 3: points(1) = 7
points(2) = 9: points(3) = 2
points(4) = 3: points(5) = 5
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
' Create a line object in model space
Dim lineObj As AcadLine
startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
' Create a circle object in model space
Dim circObj As AcadCircle
Dim centerPt(0 To 2) As Double
Dim radius As Double
centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
radius = 3
Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
' Create an ellipse object in model space
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ZoomAll
' Iterate through the model space collection.
' Collect the objects found into an array of objects
' to be added to the selection set.
ReDim ssobjs(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity
Dim I As Integer
For I = 0 To ThisDrawing.ModelSpace.Count - 1
Set ssobjs(I) = ThisDrawing.ModelSpace.Item(I)
Next
' Add the array of objects to the selection set
ssetObj.AddItems ssobjs
GoSub LISTOBJS
' Remove two of the objects from the selection set
Dim removeObjects(0 To 1) As AcadEntity
Set removeObjects(0) = ellObj
Set removeObjects(1) = circObj
ssetObj.RemoveItems removeObjects
MsgBox "The ellipse and circle have been removed from the selection set."
GoSub LISTOBJS
Exit Sub
LISTOBJS:
' List all the objects in the selection set
If ssetObj.Count = 0 Then
MsgBox "The selection set is empty"
Else
For I = 0 To ssetObj.Count - 1
MsgBox "The selection set contains: " & ssetObj.Item(I).ObjectName
Next
End If
Return
可视化 LISP: (vl-load-com)
(defun c:Example_RemoveItems()
;; This example creates a selection set and several objects.
;; It adds the objects to the selection set, and then
;; removes two of the objects from the selection set.
;; Create the new selection set
(setq ssetObj (vla-Add (vla-get-SelectionSets doc) "TEST_SELECTIONSET"))
;; Create a Ray object in model space
(setq basePoint (vlax-3d-point 3 3 0)
secondPoint (vlax-3d-point 1 3 0))
(setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
;; Create a polyline object in model space
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
(vlax-safearray-fill points '(3 7
9 2
3 5
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Closed plineObj :vlax-true)
;; Create a line object in model space
(setq startPoint (vlax-3d-point 0 0 0)
endPoint (vlax-3d-point 2 2 0))
;; Create a circle object in model space
(setq centerPt (vlax-3d-point 20 30 0)
radius 3)
(setq circObj (vla-AddCircle modelSpace centerPt radius))
;; Create an ellipse object in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
;; Iterate through the model space collection.
;; Collect the objects found into an array of objects
;; to be added to the selection set.
(setq ssobjs (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count modelSpace) 1))))
(setq cnt 0)
(vlax-for each-item modelSpace
(vlax-safearray-put-element ssobjs cnt each-item)
(setq cnt (1+ cnt))
;; Add the array of objects to the selection set
(vla-AddItems ssetObj ssobjs)
;; List all the objects in the selection set
(setq I 0)
(if (= (vla-get-Count ssetObj) 0)
(alert "The selection set is empty")
(while (>= (1- (vla-get-Count ssetObj)) I)
(alert (strcat "The selection set contains: " (vla-get-ObjectName (vla-Item ssetObj I))))
(setq I (1+ I))
;; Remove two of the objects from the selection set
(setq removeObjects (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element removeObjects 0 ellObj)
(vlax-safearray-put-element removeObjects 1 circObj)
(vla-RemoveItems ssetObj removeObjects)
(alert "The ellipse and circle have been removed from the selection set.")
(setq I 0)
(setq I (1+ I))
(vla-Delete ssetObj)
GMT+8, 2026-10-27 19:49
