RealToString 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 857| 评论: 0|原作者: admin|来自: AutoCAD
将实数(双精度)值转换为字符串。
RetVal = object.RealToString(Value, Unit, Precision)
类型: 实用程序
此方法应用到的对象。
价值
访问:仅输入
类型:双
要转换的值。
单位
访问:仅输入
类型:枚举AcUnits
  • acDefaultUnits
  • acScientific
  • acDecimal
  • acEngineering
  • acArchitectural
  • acFractional
精度
访问:仅输入
类型:长
值的精度。介于 0 和 8 之间的整数。
返回值 (RetVal)
类型:字符串
格式正确的字符串的值。
Sub Example_RealToString()
    ' This example converts values in a given format to their string equivalents.
    Dim unit As Long
    Dim valueAsStr As String
    Dim precision As Integer
    Dim valueAsReal As Double
    precision = 6
    ' Convert a real value 17.5 using Scientific mode to a String
    unit = acScientific
    valueAsStr = ThisDrawing.Utility.RealToString(17.5, unit, precision)
    MsgBox "17.5 in scientific format is " & valueAsStr, , "RealToString Example"
    ' Convert a real value 17.5 using Decimal mode to a String
    unit = acDecimal
    MsgBox "17.5 in decimal format is " & valueAsStr, , "RealToString Example"
    ' Convert a real value 17.5 using Engineering mode to a String
    unit = acEngineering
    MsgBox "17.5 in engineering format is " & valueAsStr, , "RealToString Example"
    ' Convert a real value 17.5 using Architectural mode to a String
    unit = acArchitectural
    MsgBox "17.5 in architectural format is " & valueAsStr, , "RealToString Example"
    ' Converts a real value 17.5 using fractional mode to a String
    unit = acFractional
    MsgBox "17.5 in fractional format is " & valueAsStr, , "RealToString Example"
(defun c:Example_RealToString()
    ;; This example converts values in a given format to their string equivalents.
    (setq precision 6)
    ;; Convert a real value 17.5 using Scientific mode to a String
    (setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acScientific precision))
    (alert (strcat "17.5 in scientific format is " valueAsStr))
    ;; Convert a real value 17.5 using Decimal mode to a String
    (setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acDecimal precision))
    (alert (strcat "17.5 in decimal format is " valueAsStr))
    ;; Convert a real value 17.5 using Engineering mode to a String
    (setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acEngineering precision))
    (alert (strcat "17.5 in engineering format is " valueAsStr))
    ;; Convert a real value 17.5 using Architectural mode to a String
    (setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acArchitectural precision))
    (alert (strcat "17.5 in architectural format is " valueAsStr))
    ;; Converts a real value 17.5 using fractional mode to a String
    (setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acFractional precision))
    (alert (strcat "17.5 in fractional format is " valueAsStr))
GMT+8, 2026-10-17 03:48
