PurgeFitData 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 683| 评论: 0|原作者: admin|来自: AutoCAD
清除样条曲线的拟合数据。
object.PurgeFitData
类型:样条曲线
此方法应用到的对象。
返回值 (RetVal)
无返回值。
移除样条曲线的拟合数据。
Sub Example_PurgeFitData()
    ' This example creates a spline object in model space.
    ' It then returns the current number of fit points,
    ' and then purges the fit data.
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    MsgBox "Before the purge there are " & splineObj.NumberOfFitPoints & " fit points.", , "PurgeFitData Example"
    ' Purge the fit data
    splineObj.PurgeFitData
    ThisDrawing.Regen True
    MsgBox "After the purge there are " & splineObj.NumberOfFitPoints & " fit points.", , "PurgeFitData Example"
(defun c:Example_PurgeFitData()
    ;; This example creates a spline object in model space.
    ;; It then returns the current number of fit points,
    ;; and then purges the fit data.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    (alert (strcat "Before the purge there are " (itoa (vla-get-NumberOfFitPoints splineObj)) " fit points."))
    ;; Purge the fit data
    (vla-PurgeFitData splineObj)
    (vla-Regen doc :vlax-true)
    (alert (strcat "After the purge there are " (itoa (vla-get-NumberOfFitPoints splineObj)) " fit points."))
GMT+8, 2026-11-30 10:56
