ListARX 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 600| 评论: 0|原作者: admin|来自: AutoCAD
获取当前加载的 ObjectARX 应用程序。
RetVal = object.ListArx
类型: 应用
此方法应用到的对象。
返回值 (RetVal)
类型:变体
当前加载的 ObjectARX 应用程序数组。如果当前未加载任何应用程序,则返回空。
Sub Example_ListARX()
    ' This example gets all the loaded ObjectARX applications
    ' Get the list of applications
    Dim appList As Variant
    appList = ThisDrawing.Application.ListArx
    ' Iterate through the list, and display the names, if any.
    If VarType(appList) <> vbEmpty Then
        Dim I As Integer
        For I = LBound(appList) To UBound(appList)
            MsgBox "ObjectARX application name: " & appList(I)
        Next
    Else
        MsgBox "No ObjectARX applications present."
    End If
(defun c:Example_ListARX()
    ;; This example gets all the loaded ObjectARX applications
    ;; Get the list of applications
    (setq appList (vla-ListArx acadObj))
    ;; Iterate through the list, and display the names, if any.
    (if (/= (vlax-variant-value appList) vlax-vbEmpty)
        (progn
            (setq I 0
                  appList (vlax-variant-value appList))
            (while (>= (vlax-safearray-get-u-bound appList 1) I)
                (alert (strcat "ObjectARX application name: " (vlax-safearray-get-element appList I)))
                (setq I (1+ I))
        (alert "No ObjectARX applications present.")
GMT+8, 2026-11-30 10:51
