GetReal 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 933| 评论: 0|原作者: admin|来自: AutoCAD
从用户获取实际(双精度)值。
RetVal = object.GetReal([Prompt])
类型: 实用程序
此方法应用到的对象。
提示
访问:仅输入;自选
类型:变体(字符串)
用于提示用户输入的文本。
返回值 (RetVal)
类型:双
从用户返回的值。
AutoCAD 暂停用户输入的实际值,并将返回值设置为用户输入的值。Prompt 参数指定 AutoCAD 在暂停之前显示的字符串。提示是可选的。
如果返回关键字而不是双精度键,AutoCAD 将生成错误消息“用户输入关键字”。使用该方法从返回值中获取关键字。GetInput
Sub Example_GetReal()
    ' This example returns the Real entered by the user.
    Dim returnReal As Double
    ' Return the value entered by user. A prompt is provided.
    returnReal = ThisDrawing.Utility.GetReal("Enter an Real: ")
    MsgBox "The real entered was " & returnReal & vbCrLf & _
            "(Enter the next value without prompting.)", , "GetReal Example"
    ' Return the value entered by user. No prompt is provided.
    returnReal = ThisDrawing.Utility.GetReal()
    MsgBox "The real entered was " & returnReal, , "GetReal Example"
(defun c:Example_GetReal()
    ;; This example returns the Real entered by the user.
    ;; Return the value entered by user. A prompt is provided.
    (setq returnReal (vla-GetReal (vla-get-Utility doc) "Enter an Real: "))
    (alert (strcat "The real entered was " (rtos returnReal 2) "\n"
                   "(Enter the next value without prompting.)"))
    ;; Return the value entered by user. No prompt is provided.
    (setq returnReal (vla-GetReal (vla-get-Utility doc)))
    (alert (strcat "The real entered was " (rtos returnReal 2)))
GMT+8, 2026-11-3 12:46
