GetPlotStyleTableNames 方法 (ActiveX)
获取所有可用的打印样式表名称。 支持的平台:仅限 Windows 返回值 (RetVal)类型:变体(字符串数组) 系统的可用打印样式表名称的数组。 言论您应该在首次使用此方法之前调用。调用后,除非您的绘图设备信息在会话期间发生更改,否则无需再次调用它。RefreshPlotDeviceInfoRefreshPlotDeviceInfo GetPlotStyleTableNames返回在系统上找到的所有可用打印样式表,包括 CTB 和 STB 文件。要筛选一种类型的打印样式表的结果,请使用 PSTYLEMODE 系统变量。 例子VBA: Sub Example_GetPlotStyleTableNames()
' This example gets the current plot device information
' and then displays the list of plot device names,
' media names, localized media names, and plot style
' table entries.
Dim Layout As ACADLayout
Set Layout = ThisDrawing.ModelSpace.Layout
' Refresh the current plot information for
' this session.
Layout.RefreshPlotDeviceInfo
' List all the valid device names for the system
Dim plotDevices As Variant
plotDevices = Layout.GetPlotDeviceNames()
Dim x As Integer
For x = LBound(plotDevices) To UBound(plotDevices)
MsgBox plotDevices(x)
Next
' List all the media names, and their localized version
Dim mediaNames As Variant
mediaNames = Layout.GetCanonicalMediaNames()
For x = LBound(mediaNames) To UBound(mediaNames)
MsgBox mediaNames(x)
MsgBox Layout.GetLocaleMediaName(mediaNames(x))
Next
' List all the entries in the plot style table
Dim styleNames As Variant
styleNames = Layout.GetPlotStyleTableNames()
For x = LBound(styleNames) To UBound(styleNames)
MsgBox styleNames(x)
Next
可视化 LISP: (vl-load-com)
(defun c:Example_GetPlotStyleTableNames()
;; This example gets the current plot device information
;; and then displays the list of plot device names,
;; media names, localized media names, and plot style
;; table entries.
(setq Layout (vla-get-Layout (vla-get-ModelSpace doc)))
;; Refresh the current plot information for
;; this session.
(vla-RefreshPlotDeviceInfo Layout)
;; List all the valid device names for the system
(setq plotDevices (vlax-variant-value (vla-GetPlotDeviceNames Layout)))
(setq x 0)
(while (>= (vlax-safearray-get-u-bound plotDevices 1) x)
(alert (vlax-safearray-get-element plotDevices x))
(setq x (1+ x))
;; List all the media names, and their localized version
(setq mediaNames (vlax-variant-value (vla-GetCanonicalMediaNames Layout)))
(setq x 0)
(while (>= (vlax-safearray-get-u-bound mediaNames 1) x)
(alert (vlax-safearray-get-element mediaNames x))
(alert (vla-GetLocaleMediaName Layout (vlax-safearray-get-element mediaNames x)))
(setq x (1+ x))
;; List all the entries in the plot style table
(setq styleNames (vlax-variant-value (vla-GetPlotStyleTableNames Layout)))
(setq x 0)
(while (>= (vlax-safearray-get-u-bound styleNames 1) x)
(alert (vlax-safearray-get-element styleNames x))
(setq x (1+ x))
GMT+8, 2026-11-30 11:06
