GetPlotDeviceNames 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 861| 评论: 0|原作者: admin|来自: AutoCAD
获取所有可用的打印设备名称。
RetVal = object.GetPlotDeviceNames()
类型:布局、PlotConfiguration
此方法应用到的对象。
返回值 (RetVal)
类型:变体(字符串数组)
系统的可用设备名称数组。
您应该在首次使用此方法之前调用。调用后,除非您的绘图设备信息在会话期间发生更改,否则无需再次调用它。RefreshPlotDeviceInfoRefreshPlotDeviceInfo
Sub Example_GetPlotDeviceNames()
    ' This example gets the current plot device information
    ' and then displays the list of plot device names,
    ' media names, localized media names, and plot style
    ' table entries.
    Dim Layout As ACADLayout
    Set Layout = ThisDrawing.ModelSpace.Layout
    ' Refresh the current plot information for
    ' this session.
    Layout.RefreshPlotDeviceInfo
    ' List all the valid device names for the system
    Dim plotDevices As Variant
    plotDevices = Layout.GetPlotDeviceNames()
    Dim x As Integer
    For x = LBound(plotDevices) To UBound(plotDevices)
        MsgBox plotDevices(x)
    Next
    ' List all the media names, and their localized version
    Dim mediaNames As Variant
    mediaNames = Layout.GetCanonicalMediaNames()
    For x = LBound(mediaNames) To UBound(mediaNames)
        MsgBox mediaNames(x)
        MsgBox Layout.GetLocaleMediaName(mediaNames(x))
    Next
    ' List all the entries in the plot style table
    Dim styleNames As Variant
    styleNames = Layout.GetPlotStyleTableNames()
    For x = LBound(styleNames) To UBound(styleNames)
        MsgBox styleNames(x)
    Next
(defun c:Example_GetPlotDeviceNames()
    ;; This example gets the current plot device information
    ;; and then displays the list of plot device names,
    ;; media names, localized media names, and plot style
    ;; table entries.
    (setq Layout (vla-get-Layout (vla-get-ModelSpace doc)))
    ;; Refresh the current plot information for
    ;; this session.
    (vla-RefreshPlotDeviceInfo Layout)
    ;; List all the valid device names for the system
    (setq plotDevices (vlax-variant-value (vla-GetPlotDeviceNames Layout)))
    (setq x 0)
    (while (>= (vlax-safearray-get-u-bound plotDevices 1) x)
        (alert (vlax-safearray-get-element plotDevices x))
        (setq x (1+ x))
    ;; List all the media names, and their localized version
    (setq mediaNames (vlax-variant-value (vla-GetCanonicalMediaNames Layout)))
    (setq x 0)
    (while (>= (vlax-safearray-get-u-bound mediaNames 1) x)
        (alert (vlax-safearray-get-element mediaNames x))
        (alert (vla-GetLocaleMediaName Layout (vlax-safearray-get-element mediaNames x)))
        (setq x (1+ x))
    ;; List all the entries in the plot style table
    (setq styleNames (vlax-variant-value (vla-GetPlotStyleTableNames Layout)))
    (setq x 0)
    (while (>= (vlax-safearray-get-u-bound styleNames 1) x)
        (alert (vlax-safearray-get-element styleNames x))
        (setq x (1+ x))
GMT+8, 2026-11-30 11:06
