GetPaperSize 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 829| 评论: 0|原作者: admin|来自: AutoCAD
获取已配置纸张的宽度和高度。
object.GetPaperSize Width, Height
类型:布局、PlotConfiguration
此方法应用到的对象。
宽度
访问:仅输出
类型:双
纸张的宽度。
高度
访问:仅输出
类型:双
纸张的高度。
返回值 (RetVal)
无返回值。
宽度和高度值的单位由属性指定。PaperUnits
若要设置纸张大小,请使用属性。CanonicalMediaName
Sub Example_GetPaperSize()
    ' This example gets the width and height of the default
    ' paper size for your system.
    Dim PaperWidth As Double
    Dim PaperHeight As Double
    ThisDrawing.ActiveLayout.GetPaperSize PaperWidth, PaperHeight
    MsgBox "The default paper size is " & vbCrLf & _
           "Width: " & PaperWidth & vbCrLf & _
           "Height: " & PaperHeight
(defun c:Example_GetPaperSize()
    ;; This example gets the width and height of the default
    ;; paper size for your system.
    (vla-GetPaperSize (vla-get-ActiveLayout doc) 'PaperWidth 'PaperHeight)
    (alert (strcat "The default paper size is "
                   "\nWidth: " (rtos PaperWidth 2)
                   "\nHeight: " (rtos PaperHeight 2)))
GMT+8, 2026-10-28 09:04
