GetObject 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 948| 评论: 0|原作者: admin|来自: AutoCAD
获取字典中的对象,给定对象的名称(关键字)。
RetVal = object.GetObject(Name)
类型: 字典
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
字典中对象的名称(关键字)。
返回值 (RetVal)
类型:对象
与给定名称(关键字)相对应的对象。
例如,在以下字典中查询名称“SecondKeyword”将返回对象“Object2”:
我的词典
关键字 - 对象
FirstKeyword - 对象 1
SecondKeyword - 对象 2
Sub Example_GetObject()
    ' This example creates a dictionary and adds
    ' a custom object to that dictionary. It then
    ' returns the object using GetObject.
    Dim dictObj As AcadDictionary
    Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
    ' Load the ARX application that defines the custom object.
    ' Note: The application listed here does not exist and
    ' will cause an error when run. Change the application name
    ' to the path and name of your ARX Application.
    On Error GoTo ERRORHANDLER
    ThisDrawing.Application.LoadArx "MyARXApp.dll"
    ' Create the custom object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As AcadObject
    keyName = "OBJ1"
    className = "CAsdkDictObject"
    Set customObj = dictObj.AddObject(keyName, className)
    ' Find the object
    Dim tempObj As Object
    Set tempObj = dictObj.GetObject(keyName)
ERRORHANDLER:
    MsgBox Err.Description, , "GetObject Example"
(defun c:Example_GetObject()
    ;; This example creates a dictionary and adds
    ;; a custom object to that dictionary.
    (setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
    ;; Load the ObjectARX application that defines the custom object.
    ;; Note: The application listed here does not exist and
    ;; will cause an error when run. Change the application name
    ;; to the path and name of your ObjectARX application.
    (vla-LoadArx acadObj "MyARXApp.dll")
    ;; Create the custom object in the dictionary
    (setq keyName "OBJ1")
    (setq className "CAsdkDictObject")
    (setq customObj (vla-AddObject dictObj keyName className))
    ;; Find the object
    (setq tempObj (vla-GetObject dictObj keyName))
GMT+8, 2026-10-27 23:54
