GetLoopAt 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 790| 评论: 0|原作者: admin|来自: AutoCAD
获取给定索引处的填充循环。
object.GetLoopAt Index, Loop
类型:舱口
此方法应用到的对象。
指数
访问:仅输入
类型:整数
以 0 开头的正整数。
圈
访问:仅输出
类型:变体(对象或对象数组)
组成循环的对象或对象数组。
返回值 (RetVal)
无返回值。
Sub Example_GetLoopAt()
    ' This example creates an associative hatch in model space.
    ' It then finds the objects that make up the first loop of the hatch.
    Dim hatchObj As AcadHatch
    Dim patternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    ' Define the hatch
    patternName = "ANSI31"
    PatternType = 0
    bAssociativity = True
    ' Create the associative Hatch object
    Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
    ' Create the outer loop for the hatch.
    ' An arc and a line are used to create a closed loop.
    Dim outerLoop(0 To 1) As AcadEntity
    Dim center(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    center(0) = 5: center(1) = 3: center(2) = 0
    radius = 3
    startAngle = 0
    endAngle = 3.141592
    Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
    Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
    ' Append the outer loop to the hatch object
    hatchObj.AppendOuterLoop (outerLoop)
    ' Append the first circle as one inner loop
    Dim innerLoop1(0) As AcadEntity
    center(0) = 5: center(1) = 4.5: center(2) = 0
    radius = 1
    Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
    hatchObj.AppendInnerLoop (innerLoop1)
    ' Append the second circle as the other inner loop
    Dim innerLoop2(0) As AcadEntity
    radius = 0.5
    Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
    hatchObj.AppendInnerLoop (innerLoop2)
    ' Evaluate and display the hatch
    hatchObj.Evaluate
    ThisDrawing.Regen True
    ' Find the objects that make up the first loop
    Dim loopObjs As Variant
    hatchObj.GetLoopAt 0, loopObjs
    ' Find the types of the objects in the loop
    Dim I As Integer
    Dim objName As String
    objName = ""
    For I = LBound(loopObjs) To UBound(loopObjs)
        objName = objName & loopObjs(I).EntityName & ", "
    Next
    MsgBox "The objects in the first loop of the hatch are: " & objName, , "GetLoopAt Example"
(defun c:Example_GetLoopAt()
    ;; This example creates an associative hatch in model space.
    ;; It then finds the objects that make up the first loop of the hatch.
    ;; Define the hatch
    (setq patternName "ANSI31"
          patternType acHatchPatternTypePreDefined
          bAssociativity :vlax-true)
    ;; Create the associative Hatch object
    (setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
    ;; Create the outer loop for the hatch.
    ;; An arc and a line are used to create a closed loop.
    (setq center (vlax-3d-point 5 3 0)
          radius 3
          startAngle 0
          endAngle 3.141592)
    (setq arcObj (vla-AddArc modelSpace center radius startAngle endAngle))
    (setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj)))
    (setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element outerLoop 0 arcObj)
    (vlax-safearray-put-element outerLoop 1 lineObj)
    ;; Append the outer loop to the hatch object
    (vla-AppendOuterLoop hatchObj outerLoop)
    ;; Append the first circle as one inner loop
    (setq center (vlax-3d-point 5 4.5 0)
          radius 1)
    (setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element innerLoop1 0 (vla-AddCircle modelSpace center radius))
    (vla-AppendInnerLoop hatchObj innerLoop1)
    ;; Append the second circle as the other inner loop
    (setq radius 0.5)
    (setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (vlax-safearray-put-element innerLoop2 0 (vla-AddCircle modelSpace center radius))
    (vla-AppendInnerLoop hatchObj innerLoop2)
    ;; Evaluate and display the hatch
    (vla-Evaluate hatchObj)
    (vla-Regen doc :vlax-true)
    ;; Find the objects that make up the first loop
    (vla-GetLoopAt hatchObj 0 'loopObjs)
    ;; Find the types of the objects in the loop
    (setq I 0
          objName "")
    (while (>= (vlax-safearray-get-u-bound loopObjs 1) I)
        (setq objName (strcat objName (vla-get-ObjectName (vlax-safearray-get-element loopObjs I)) ", "))
        (setq I (1+ I))
    (alert (strcat "The objects in the first loop of the hatch are: " objName))
GMT+8, 2026-10-27 09:11
