GetInvisibleEdge 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 931| 评论: 0|原作者: admin|来自: AutoCAD
获取给定索引处 3DFace 对象边缘的可见性设置。
RetVal = object.GetInvisibleEdge(Index)
类型: 3DFace
此方法应用到的对象。
指数
访问:仅输入
类型:长
要查询的边的索引。索引必须介于 0 和 3(含 0 和 3)之间。
返回值 (RetVal)
类型:布尔
  • True:边缘不可见。
  • False:边缘可见。
Sub Example_GetInvisibleEdge()
    ' This example creates a 3D face in model space.
    ' It then toggles the visibility of the  first edge.
    Dim faceObj As Acad3DFace
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    Dim point3(0 To 2) As Double
    Dim point4(0 To 2) As Double
    ' Define the four coordinates of the face
    point1(0) = 1#: point1(1) = 1#: point1(2) = 0#
    point2(0) = 5#: point2(1) = 1#: point2(2) = 1#
    point3(0) = 5#: point3(1) = 5#: point3(2) = 1#
    point4(0) = 1#: point4(1) = 10#: point4(2) = 0#
    ' Create the 3DFace object in model space
    Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
    ZoomAll
    ' Find the current visibility status of the first edge of the face
    Dim visStatus As Boolean
    visStatus = faceObj.GetInvisibleEdge(0)
    MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
    ' Toggle the visibility of the first edge of the face
    faceObj.SetInvisibleEdge 0, Not (visStatus)
    ThisDrawing.Regen False
    MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
(defun c:Example_GetInvisibleEdge()
    ;; This example creates a 3D face in model space.
    ;; It then toggles the visibility of the  first edge.
    ;; Define the four coordinates of the face
    (setq point1 (vlax-3d-point 1 1 0)
          point2 (vlax-3d-point 5 1 1)
          point3 (vlax-3d-point 5 5 1)
          point4 (vlax-3d-point 1 10 0))
    ;; Create the 3DFace object in model space
    (setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4))
    (vla-ZoomAll acadObj)
    ;; Find the current visibility status of the first edge of the face
    (setq visStatus (vla-GetInvisibleEdge faceObj 0))
    (alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible.")))
    ;; Toggle the visibility of the first edge of the face
    (vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true))
    (vla-Regen doc :vlax-false)
    (alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible.")))
GMT+8, 2026-10-28 07:35
