GetExtensionDictionary 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 653| 评论: 0|原作者: admin|来自: AutoCAD
获取与对象关联的扩展字典。
RetVal = object.GetExtensionDictionary
类型:所有图形对象AttributeReferenceBlockDictionaryDimensionDimStyleGroupLayerLayoutLinetypeMaterialMLeaderStylePlotConfigurationRegisteredApplicationTableStyleTextStyleUCSViewViewportXRecord
此方法应用到的对象。
返回值 (RetVal)
类型: 字典
对象的扩展字典。
如果对象没有扩展字典,此方法将为该对象创建一个新的扩展字典,并在返回值中返回它。
可以使用该属性查询对象以查看它是否具有扩展字典。HasExtensionDictionary
Sub Example_GetExtensionDictionary()
    ' This example creates a Circle object in model space and
    ' adds a new Extension Dictionary to the Circle object
    Dim EDictionary As AcadDictionary
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    MsgBox "Circle object Extension Dictionary state before: " & circleObj.HasExtensionDictionary
    ' Create an Extension Dictionary for the new Circle
    Set EDictionary = circleObj.GetExtensionDictionary
    MsgBox "Circle object Extension Dictionary state after: " & circleObj.HasExtensionDictionary
(defun c:Example_GetExtensionDictionary()
    ;; This example creates a Circle object in model space and
    ;; adds a new Extension Dictionary to the Circle object
    ;; Define the Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    (alert (strcat "Circle object Extension Dictionary state before: " (if (= (vla-get-HasExtensionDictionary circleObj) :vlax-true) "True" "False")))
    ;; Create an Extension Dictionary for the new Circle
    (setq EDictionary (vla-GetExtensionDictionary circleObj))
    (alert (strcat "Circle object Extension Dictionary state after: " (if (= (vla-get-HasExtensionDictionary circleObj) :vlax-true) "True" "False")))
GMT+8, 2026-9-12 21:57
