GetDistance 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 544| 评论: 0|原作者: admin|来自: AutoCAD
获取与提示线或屏幕上选定的一组点的距离。
RetVal = object.GetDistance([Point [, Prompt]])
类型: 实用程序
此方法应用到的对象。
访问:仅输入;自选
类型:变体(双打的三元素阵列)
指定基点的 3D WCS 坐标。如果未提供此点,则用户必须输入两个点。
提示
访问:仅输入;自选
类型:变体(字符串)
要显示的文本,用于提示用户输入。
返回值 (RetVal)
类型:变体(双精度或双精度数组)
与屏幕上的提示线或一组选定点的距离。
AutoCAD 暂停用户输入线性距离,并将返回值设置为选定距离的值。Point 参数指定 WCS 坐标中的基点。Prompt 参数指定 AutoCAD 在暂停之前显示的字符串。“点”和“提示”都是可选的。
AutoCAD 用户可以通过以当前单位格式输入数字来指定距离。用户还可以通过在图形屏幕上指定两个位置来设置距离。AutoCAD 绘制从第一个点到当前十字准线位置的橡皮筋线,以帮助用户可视化距离。如果提供了“点”参数,AutoCAD 将使用此值作为两个点中的第一个点。
默认情况下,将 Point 和返回值视为三维点。对该方法的先前调用可以强制 Point 为二维,从而确保此方法返回平面距离。GetDistanceInitializeUserInput
无论使用何种方法指定距离或当前线性单位(例如,英尺和英寸),此方法始终将返回值设置为双精度浮点值。
Sub Example_GetDistance()
    ' This example returns the distance entered by the user.
    Dim returnDist As Double
    Dim basePnt(0 To 2) As Double
    basePnt(0) = 0#: basePnt(1) = 0#: basePnt(2) = 0#
    ' Return the value entered by user. A prompt is provided.
    returnDist = ThisDrawing.Utility.GetDistance(, "Enter distance: ")
    MsgBox "The distance entered was " & returnDist & vbCrLf & _
            "(Enter the next value without prompting.)", , "GetDistance Example"
    ' Return the value entered by user. No prompt is provided.
    returnDist = ThisDrawing.Utility.GetDistance()
    MsgBox "The distance entered was " & returnDist, , "GetDistance Example"
    ' Return the value entered by user. A base point and prompt are provided.
    returnDist = ThisDrawing.Utility.GetDistance(basePnt, "Enter a distance: ")
(defun c:Example_GetDistance()
    ;; This example returns the distance entered by the user.
    ;; Return the value entered by user. A prompt is provided.
    (setq returnDist (vla-GetDistance (vla-get-Utility doc) nil "Enter distance: "))
    (alert (strcat "The distance entered was " (rtos returnDist 2) "\n"
            "(Enter the next value without prompting.)"))
    ;; Return the value entered by user. No prompt is provided.
    (setq returnDist (vla-GetDistance (vla-get-Utility doc)))
    (alert (strcat "The distance entered was " (rtos returnDist 2)))
    ;; Return the value entered by user. A base point and prompt are provided.
    (setq basePnt (vlax-3d-point 0 0 0))
    (setq returnDist (vla-GetDistance (vla-get-Utility doc) basePnt "Enter a distance: "))
GMT+8, 2026-9-15 05:28
