Explode 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 961| 评论: 0|原作者: admin|来自: AutoCAD
将复合对象分解为子实体。
RetVal = object.Explode
类型:3DPolyline、BlockReference、ComparedReference、ExternalReference、LWPolyline、MInsertBlock、PolygonMesh、折线、区域
此方法应用到的对象。
返回值 (RetVal)
类型:变体(对象数组)
分解对象的数组。
根据要爆炸的复合物体的类型,会出现不同的结果。有关可分解对象及其结果的详细列表,请参见《AutoCAD 命令参考》中的 EXPLODE 命令主题。
您不必为了操纵其组成实体而分解块。所有块定义都有一个方法,允许您在不分解块定义本身的情况下操作块中的实体。Item
注意:和 对象继承此方法,但此方法在使用时不会影响任一对象类型。ComparedReferenceExternalReferenceBlockReference
Sub Example_Explode()
    ' This example creates a lightweight polyline in model space.
    ' It then explodes the polyline.
    Dim points(0 To 11) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 1
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ' Set the bulge on one segment to vary the
    ' type of objects in the polyline
    plineObj.SetBulge 3, -0.5
    ZoomAll
    ' Explode the polyline
    MsgBox "Explode the polyline?", , "Explode Example"
    Dim explodedObjects As Variant
    explodedObjects = plineObj.Explode
    ' Loop through the exploded objects
    Dim I As Integer
    For I = 0 To UBound(explodedObjects)
        explodedObjects(I).Update
        MsgBox "Exploded Object " & I & ": " & explodedObjects(I).ObjectName, , "Explode Example"
        explodedObjects(I).Color = acByLayer
    Next
(defun c:Example_Explode()
    ;; This example creates a lightweight polyline in model space.
    ;; It then explodes the polyline.
    ;; Define the 2D polyline points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill points '(1 1
				                              1 2
				                              2 2
				                              3 2
				                              4 4
				                              4 1
    ;; Create a lightweight Polyline object in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-put-Color plineObj acRed)
    ;; Set the bulge on one segment to vary the
    ;; type of objects in the polyline
    (vla-SetBulge plineObj 3 -0.5)
    (vla-ZoomAll acadObj)
    ;; Explode the polyline
    (alert "Explode the polyline?")
    (setq explodedObjects (vlax-variant-value (vla-Explode plineObj)))
    ;; Loop through the exploded objects
    (setq I 0)
    (while (>= (vlax-safearray-get-u-bound explodedObjects 1) I)
        (vla-Update (vlax-safearray-get-element explodedObjects I))
        (alert (strcat "Exploded Object " (itoa I) ": " (vla-get-ObjectName (vlax-safearray-get-element explodedObjects I))))
        (vla-put-Color (vlax-safearray-get-element explodedObjects I) acByLayer)
        (setq I (1+ I))
GMT+8, 2026-11-25 15:27
