DeleteProfile 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 933| 评论: 0|原作者: admin|来自: AutoCAD
删除指定的配置文件。
object.DeleteProfile ProfileName
类型:PreferencesProfiles
此方法应用到的对象。
配置文件名称
访问:仅输入
类型:字符串
要删除的配置文件的名称。
返回值 (RetVal)
无返回值。
Sub Example_DeleteProfile()
    ' This example deletes a profile.
    Dim strProfileToDelete As String
    Set preferences = ThisDrawing.Application.preferences
    ' Specify the profile to delete.
    strProfileToDelete = "TestProfile"
    ' Delete the profile
    ' The call will fail if "TestProfile" does not exist or
    ' if "TestProfile" is the current profile.
    On Error GoTo Error
    preferences.Profiles.DeleteProfile strProfileToDelete
    Exit Sub
Error:
    MsgBox "DeleteProfile of " & strProfileToDelete & " failed. " & Err.Description, , "DeleteProfile Example"
(defun c:Example_DeleteProfile()
    ;; This example deletes a profile.
    ;; Specify the profile to delete.
    (setq strProfileToDelete "TestProfile")
    (vla-CopyProfile (vla-get-Profiles preferences) "<<Unnamed Profile>>" strProfileToDelete)
    (alert (strcat "Profile " strProfileToDelete " created from <<Unnamed Profile>>."))
    ;; Delete the profile
    ;; The call will fail if "TestProfile" does not exist or
    ;; if "TestProfile" is the current profile.
    (vla-DeleteProfile (vla-get-Profiles preferences) strProfileToDelete)
    (alert (strcat "Profile " strProfileToDelete " deleted."))
GMT+8, 2026-10-17 22:09
