DeleteFitPoint 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 621| 评论: 0|原作者: admin|来自: AutoCAD
删除样条曲线在给定索引处的拟合点。
object.DeleteFitPoint Index
类型:样条曲线
此方法应用到的对象。
指数
访问:仅输入
类型:整数
拟合点列表中的索引位置。介于 0 和 N-1 之间的正整数,其中 N 是样条曲线的拟合点总数。
返回值 (RetVal)
无返回值。
AutoCAD 将移除拟合点,然后通过其余点重新调整样条曲线。样条中必须至少有三个拟合点,此方法才能成功。若要查看更改,请使用 or 方法。UpdateRegen
Sub Example_DeleteFitPoint()
    ' This example creates a spline object in model space.
    ' It then deletes a fit point from the spline.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    MsgBox "Delete the first fit point", , "DeleteFitPoint Example"
    ' Delete the first fit point in the spline
    splineObj.DeleteFitPoint 0
    ThisDrawing.Regen True
    MsgBox "A fit point has been deleted at Index: 0", , "DeleteFitPoint Example"
(defun c:Example_DeleteFitPoint()
    ;; This example creates a spline object in model space.
    ;; It then deletes a fit point from the spline.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
				                                 5 5 0
				                                 10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    (alert "Delete the first fit point.")
    ;; Delete the first fit point in the spline
    (vla-DeleteFitPoint splineObj 0)
    (vla-Regen doc :vlax-true)
    (alert "A fit point has been deleted at Index: 0")
GMT+8, 2026-10-18 01:59
