DeleteContent 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 820| 评论: 0|原作者: admin|来自: AutoCAD
删除单元格的内容。
object.DeleteContent nRow, nCol
类型: 表格
此方法应用到的对象。
nRow(n行)
访问:仅输入
类型:长
要删除的单元格的行号。
nCol (英语:nCol)
访问:仅输入
类型:长
要删除的单元格的列号。
返回值 (RetVal)
无返回值。
Sub Example_ContentChange()
    ' This example adds a table in model space
    ' and manipulates its contents
    ' Note: One content is created for each cell by default;
    ' this function need to be called only to create additional contents.
    Dim MyModelSpace As AcadModelSpace
    Set MyModelSpace = ThisDrawing.modelSpace
    Dim pt(2) As Double
    Dim MyTable As IAcadTable
    Dim sID As Long
    Dim newSID As Long
    Dim row As Long
    Dim col As Long
    ' Creates arbitrary cell points to check
    row = 2
    col = 2
    ' Creates the table with an arbitrary number of cells
    Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
    If MyTable.IsEmpty(row, col) Then
        If MyTable.IsContentEditable(row, col) Then
            MsgBox "There is no content in the cell, but it is editable"
        End If
    End If
    ' Create some content in an arbitrary cell
    sID = MyTable.CreateContent(row, col, 8)
    MsgBox "The content ID is " & sID
    ' Move the content to another index
    MyTable.MoveContent row, col, sID, 4
    ' Check that the content has been deleted
    MyTable.DeleteContent row, col
        End If
    End If
    ZoomExtents
(defun c:Example_ContentChange()
    ;; This example adds a table in model space
    ;; and manipulates its contents
    ;; Note: One content is created for each cell by default;
    ;; this function need to be called only to create additional contents.
    (setq pt (vlax-3d-point 0 0 0))
    ;; Creates arbitrary cell points to check
    (setq row 2
          col 2)
    ;; Creates the table with an arbitrary number of cells
    (setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
    (vla-SetTextHeight MyTable (+ acDataRow acHeaderRow acTitleRow) 1)
    (vla-Regen doc :vlax-true)
    (vla-ZoomExtents acadObj)
    (if (= (vla-IsEmpty MyTable row col) :vlax-true)
        (if (= (vla-IsContentEditable MyTable row col) :vlax-true)
            (alert "There is no content in the cell, but it is editable")
    ;; Create some content in an arbitrary cell
    (setq sID1 (vla-CreateContent MyTable row col 0))
    (setq sID2 (vla-CreateContent MyTable row col 1))
    (vla-SetTextString MyTable row col sID1 "Value1")
    (vla-SetTextString MyTable row col sID2 "Value2")
    (alert (strcat "The content IDs are "
		   "\nValue1: " (itoa sID1)
		   "\nValue2: " (itoa sID2)))
    ;; Move the content to another index
    (vla-MoveContent MyTable row col sID2 sID1)
    (alert "Content order changed")
    ;  Check that the content has been deleted
    (vla-DeleteContent MyTable row col)
GMT+8, 2026-11-25 15:26
