DeleteConfiguration 方法 (ActiveX)
删除视口配置。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论视口配置由使用该方法拆分的单个视口组成。拆分视口后,生成的视口将被视为视口配置。配置中的所有视口都与拆分前的原始视口同名。Split 例子VBA: Sub Example_DeleteConfiguration()
' This example creates a new viewport and splits
' the viewport into 4 windows.
' It then deletes the viewport configuration
Dim oldViewport As AcadViewport
Set oldViewport = ThisDrawing.ActiveViewport
' Create a new viewport and make it active
Dim newViewport As AcadViewport
Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
ThisDrawing.ActiveViewport = newViewport
' Split the viewport in 4 windows
newViewport.Split acViewport4
' Make the newly split viewport active
MsgBox "The viewport configuration split into 4 windows."
' Delete the viewport configuration
ThisDrawing.ActiveViewport = oldViewport
ThisDrawing.Viewports.DeleteConfiguration ("TESTVIEWPORT")
MsgBox "The viewport configuration has been deleted."
可视化 LISP: (vl-load-com)
(defun c:Example_DeleteConfiguration()
;; This example creates a new viewport and splits
;; the viewport into 4 windows.
;; It then deletes the viewport configuration
(setq oldViewport (vla-Add (vla-get-Viewports doc) "CurrentViewport"))
;; Create a new viewport and make it active
(setq newViewport (vla-Add (vla-get-Viewports doc) "NewViewport"))
(vla-put-ActiveViewport doc newViewport)
;; Split the viewport in 4 windows
(vla-Split newViewport acViewport4)
;; Make the newly split viewport active
(alert "The viewport configuration split into 4 windows.")
;; Delete the viewport configuration
(vla-put-ActiveViewport doc oldViewport)
(vla-DeleteConfiguration (vla-get-Viewports doc) "NewViewport")
(vla-DeleteConfiguration (vla-get-Viewports doc) "CurrentViewport")
(alert "The viewport configurations have been deleted and original viewport restored.")
GMT+8, 2026-11-29 10:56
