Delete 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 706| 评论: 0|原作者: admin|来自: AutoCAD
Delete 方法 (ActiveX)
删除指定对象或一组已保存的图层设置。
返回值 (RetVal)
无返回值。
删除集合中的对象时,集合中所有剩余的项都会根据当前计数重新分配一个新索引。因此,应避免在循环访问集合时删除对象的循环。例如,以下 VBA 代码将导致运行时错误:
For i = 0 To ThisDrawing.Groups.Count - 1
    ThisDrawing.Groups.Item(i).Delete
Next I
相反,请使用以下 VBA 代码删除集合中的所有成员:
For Each obj In ThisDrawing.Groups
    obj.Delete
Next obj
还可以使用以下 VBA 代码删除集合的单个成员:
ThisDrawing.Groups.Item("group1").Delete
如果尝试删除集合对象,则会导致错误。
ToolbarItem:仅当工具栏可见时,才能添加或删除工具栏项。
LayerStateManager:此对象采用参数 Name,该参数是表示要删除的图层状态的字符串。
Sub Example_Delete()
    ' This example creates a Layer named "TEST".
    ' It then iterates the Layers collection and displays
    ' the names of the available layers.
    ' It then deletes the layer "TEST", and again iterates
    ' the layers collection and displays the names of
    ' available layers.
    Dim layerObj As AcadLayer
    ' Create the new layer
    Set layerObj = ThisDrawing.Layers.Add("TEST")
    ' Display the names of the layers in the drawing
    GoSub DISPLAYLAYERS
    ' Delete the layer "TEST"
    layerObj.Delete
    ' Display the names of the layers remaining in the drawing
    GoSub DISPLAYLAYERS
    Exit Sub
DISPLAYLAYERS:
    Dim entry As AcadLayer
    Dim layerNames As String
    layerNames = ""
    For Each entry In ThisDrawing.Layers
       layerNames = layerNames & entry.name & ", "
    Next
    MsgBox "The drawing consists of the following layers:" & vbCr & layerNames, , "Delete Example"
    Return
(defun c:Example_Delete()
    ;; This example creates a Layer named "TEST".
    ;; It then iterates the Layers collection and displays
    ;; the names of the available layers.
    ;; It then deletes the layer "TEST", and again iterates
    ;; the layers collection and displays the names of
    ;; available layers.
    ;; Create the new layer
    (setq layerObj (vla-Add (vla-get-Layers doc) "TEST"))
    ;; Display the names of the layers in the drawing
    (setq layerNames "")
    (vlax-for entry (vla-get-Layers doc)
       (setq layerNames (strcat layerNames (vla-get-Name entry) ", "))
    (alert (strcat "The drawing consists of the following layers: \n" layerNames))
    ;; Delete the layer "TEST"
    (vla-Delete layerObj)
    ;; Display the names of the layers remaining in the drawing
GMT+8, 2026-11-3 12:53
