AppendVertex 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 547| 评论: 0|原作者: admin|来自: AutoCAD
将顶点追加到 3DPolyline、折线或 PolygonMesh 对象的末尾。
object.AppendVertex Point
类型:3DPolylinePolygonMesh折线
此方法应用到的对象。
访问:仅输入
类型:变体(双打的三元素阵列)
指定要追加的顶点的坐标。
PolygonMesh:指定附加顶点行的 3D WCS 坐标数组。
3DPolyline:指定要追加的顶点的 3D WCS 坐标数组。
折线:3D 坐标数组。XY 坐标在 OCS 中给出,Z 坐标被忽略。
返回值 (RetVal)
无返回值。
PolygonMesh:将顶点附加到对象的末尾时,将附加一行顶点。例如,对于 4 x 3,您定义了 12 个顶点。附加一个顶点将使矩阵为 5 x 3,因此需要三个额外的坐标。如果 4 x 3 矩阵的最后一个顶点如下:PolygonMeshPolygonMesh
  • 顶点(3,0): 6,6,6
  • 顶点(3,1): 7,7,7
  • 顶点(3,2): 8,8,8
您将附加:
  • 顶点(4,0): 10,10,10
  • 顶点(4,1): 10,5,0
  • 顶点(4,2): 10,20,30
可以使用该方法将对象的 OCS 坐标与其他坐标系相互转换。PolylineTranslateCoordinates
Sub Example_AppendVertex()
    ' This example creates a polyline in model space.
    ' It then appends a vertex to the polyline.
    Dim plineObj As AcadPolyline
    Dim points(0 To 14) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ZoomAll
    MsgBox "Append the vertex 4, 1, 0.", , "AppendVertex Example"
    Dim newVertex(0 To 2) As Double
    newVertex(0) = 4: newVertex(1) = 1: newVertex(2) = 0
    plineObj.AppendVertex newVertex
    ZoomAll
    MsgBox "The vertex 4, 1, 0 as been appended.", , "AppendVertex Example"
(defun c:Example_AppendVertex()
    ;; This example creates a polyline in model space.
    ;; It then appends a vertex to the polyline.
    ;; Define the 2D polyline points
    (setq center (vlax-make-safearray vlax-vbDouble '(0 . 14)))
    (vlax-safearray-fill center '(1 1 0
                                  1 2 0
                                  2 2 0
                                  3 2 0
                                  4 4 0
    ;; Create a lightweight Polyline object in model space
    (setq plineObj (vla-AddPolyline modelSpace points))
    (vla-ZoomAll acadObj)
    (alert "Append the vertex 4, 1, 0.")
    (setq newVertex (vlax-3d-point 4 1 0))
    (vla-AppendVertex plineObj newVertex)
    (alert "The vertex 4, 1, 0 as been appended.")
GMT+8, 2026-9-12 14:04
