AngleFromXAxis 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 789| 评论: 0|原作者: admin|来自: AutoCAD
获取线与 X 轴的角度。
RetVal = AngleFromXAxis(Point1, Point2)
类型: 实用程序
此方法应用到的对象。
第1点
访问:仅输入
类型:变体(双打的三元素阵列)
线的起点。
第2点
访问:仅输入
类型:变体(双打的三元素阵列)
线路的端点。
返回值 (RetVal)
类型:双
线的角度(以弧度为单位)。
Sub Example_AngleFromXAxis()
    ' This example finds the angle, in radians, between the X axis
    ' and a line defined by two points.
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
    Dim retAngle As Double
    pt1(0) = 2: pt1(1) = 5: pt1(2) = 0
    pt2(0) = 5: pt2(1) = 2: pt2(2) = 0
    ' Return the angle
    retAngle = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2)
    ' Create the line for a visual reference
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
    ZoomAll
    ' Display the angle found
    MsgBox "The angle in radians between the X axis and the line is " & retAngle, , "AngleFromXAxis Example"
(defun c:Example_AngleFromXAxis()
    ;; This example finds the angle, in radians, between the X axis
    ;; and a line defined by two points.
    ;; Return the angle
    (setq pt1 (vlax-3d-point 2 5 0)
          pt2 (vlax-3d-point 5 2 0))
    (setq retAngle (vla-AngleFromXAxis (vla-get-Utility doc) pt1 pt2))
    ;; Create the line for a visual reference
    (setq lineObj (vla-AddLine modelSpace pt1 pt2))
    (vla-ZoomAll acadObj)
    ;; Display the angle found
    (alert (strcat "The angle in radians between the X axis and the line is " (rtos retAngle 2)))
GMT+8, 2026-11-29 10:56
