AddXLine 方法 (ActiveX)
创建一条 xline(一条无限线),穿过两个指定点。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddXline(Point1, Point2) 言论没有其他评论。 例子VBA: Sub Example_AddXLine()
' This example creates an XLine in model space.
Dim xlineObj As AcadXline
Dim basePoint(0 To 2) As Double
Dim directionVec(0 To 2) As Double
' Define the xline
basePoint(0) = 2#: basePoint(1) = 2#: basePoint(2) = 0#
directionVec(0) = 1#: directionVec(1) = 1#: directionVec(2) = 0#
' Create the xline in model space
Set xlineObj = ThisDrawing.ModelSpace.AddXline(basePoint, directionVec)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddXLine()
;; This example creates an XLine in model space.
;; Define the xline
(setq basePoint (vlax-3d-point 2 2 0)
directionVec (vlax-3d-point 1 1 0))
;; Create the xline in model space
(setq xlineObj (vla-AddXline modelSpace basePoint directionVec))
(vla-ZoomAll acadObj)
GMT+8, 2026-11-29 23:46
