AddWedge 方法 (ActiveX)
2024-5-18 18:32| 发布者: admin| 查看: 620| 评论: 0|原作者: admin|来自: AutoCAD
在给定长度、宽度和高度的情况下,创建边平行于轴的楔块。
RetVal = object.AddWedge(Center, Length, Width, Height)
类型:块、模型空间、纸空间
此方法应用到的对象。
中心
访问:仅输入
类型:变体(双打的三元素阵列)
指定楔块面中心的 3D WCS 坐标。
长度
访问:仅输入
类型:双
对应于 X 轴的楔块长度。必须为正数。
宽度
访问:仅输入
类型:双
对应于 Y 轴的楔块宽度。必须为正数。
高度
访问:仅输入
类型:双
对应于 Z 轴的楔块高度。必须为正数。
返回值 (RetVal)
类型: 3DSolid
作为新创建楔形的对象。3DSolid
Sub Example_AddWedge()
    ' This example creates a wedge in model space.
    Dim wedgeObj As Acad3DSolid
    Dim center(0 To 2) As Double
    Dim length As Double
    Dim width As Double
    Dim height As Double
    ' Define the wedge
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 10#: width = 15#: height = 20#
    ' Create the wedge in model space
    Set wedgeObj = ThisDrawing.ModelSpace.AddWedge(center, length, width, height)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_AddWedge()
    ;; This example creates a wedge in model space.
    ;; Define the wedge
    (setq wedgeCenter (vlax-3d-point 5 5 0)
          wedgeLength 10
          wedgeWidth 15
          wedgeHeight 20)
    ;; Create the wedge in model space
    (setq wedgeObj (vla-AddWedge modelSpace wedgeCenter wedgeLength wedgeWidth wedgeHeight))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-11-29 10:54
