AddDimRotated 方法 (ActiveX)
创建旋转的线性尺寸。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDimRotated(XLine1Point, XLine2Point, DimLineLocation, RotationAngle) 言论![]() 在 45 度处创建的线性尺寸 例子VBA: Sub Example_AddDimRotated()
' This example creates a rotated dimension in model space.
Dim dimObj As AcadDimRotated
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim rotAngle As Double
' Define the dimension
point1(0) = 0#: point1(1) = 5#: point1(2) = 0#
point2(0) = 5#: point2(1) = 5#: point2(2) = 0#
location(0) = 0#: location(1) = 0#: location(2) = 0#
rotAngle = 120
rotAngle = rotAngle * 3.141592 / 180# ' covert to Radians
' Create the rotated dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimRotated(point1, point2, location, rotAngle)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddDimRotated()
;; This example creates a rotated dimension in model space.
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
location (vlax-3d-point 0 0 0)
rotAngle (/ (* 120 3.141592) 180))
;; Create the rotated dimension in model space
(setq dimObj (vla-AddDimRotated modelSpace point1 point2 location rotAngle))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-28 09:46
