ComparedReference 对象 (ActiveX)
表示要与当前图形进行比较的图形的外部参照。 支持的平台:仅限 Windows 班级信息
言论该对象从该对象继承其成员。可以使用 ActiveX 查询和编辑 AutoCAD 图形中的图元。但是,您不能使用 ActiveX 创建对象。ComparedReferenceExternalReferenceComparedReferenceComparedReference 没有允许您将对象标识为该类型的成员属性;但是,您可以将 OR 强制转换为对象类型,并使用错误处理来确定强制转换是否成功。ExternalReferenceComparedReferenceAcadEntityAcadExternalReferenceAcadComparedReference 以下代码示例演示如何使用强制转换类型来确定实体是否为 类型。ComparedReference VBA: ' Checks to see if an object is of the ComparedReference type
Sub CheckForComparedReference()
Dim ent As AcadEntity
Dim comRef As AcadComparedReference
On Error Resume Next
' Step through all the objects in model space
For Each ent In ThisDrawing.ModelSpace
' Check to see if the object is a Block Reference
If ent.ObjectName = "AcDbBlockReference" Then
' Try to cast the entity (Block Reference) to a ComparedReference
Set comRef = ent
' If an occurs, then the entity is not a ComparedReference
If Err <> 0 Then
MsgBox "Not a Compared Reference"
Else
MsgBox "Xref Name: " + comRef.Name + vbLf + "Compared Reference"
End If
' Clear the Error object
Err.Clear
End If
Next ent
可视化 LISP: (vl-load-com)
(defun c:CheckForComparedReference()
;; Checks to see if an object is of the ComparedReference type
;; Step through all the objects in model space
(vlax-for obj (vla-get-ModelSpace doc)
;; Check to see if the object is a Block Reference
(if (= (vla-get-objectname obj) "AcDbBlockReference")
(progn
;; Transform the VLA-OBJECT to an ENAME
(setq entName (vlax-vla-object->ename obj))
;; Check to see what the value of the IsComparedReference property is of the entity
(if (vl-catch-all-error-p (vl-catch-all-apply 'getpropertyvalue (list entName "IsComparedReference")))
;; If an error occurs, then the entity is not a ComparedReference
(alert "Not a Compared Reference")
(alert (strcat "Xref Name: "
(vla-get-name obj)
"\nCompared Reference"))
GMT+8, 2026-10-17 22:57
