关于创建网格 (VBA/ActiveX)
2024-5-18 18:31| 发布者: admin| 查看: 733| 评论: 0|原作者: admin|来自: AutoCAD
矩形网格(对象)使用平面刻面表示对象的表面。PolygonMesh
网格密度或小平面数是根据 M 和 N 个顶点的矩阵定义的,类似于由列和行组成的网格。M 和 N 分别指定任何给定顶点的列和行位置。您可以在 2D 和 3D 中创建网格,但它们主要用于 3D。
使用创建矩形网格的方法。此方法采用三个值作为输入:M 方向的顶点数、N 方向的顶点数以及包含网格中所有顶点坐标的变体数组。Add3DMesh
创建 后,使用 和 属性关闭网格。PolygonMeshMCloseNClose
创建多边形网格
本示例创建一个 4×4 多边形网格。然后调整活动视口的方向,以便更容易查看网格的三维性质。
Sub Ch8_Create3DMesh()
    Dim meshObj As AcadPolygonMesh
    Dim mSize, nSize, Count As Integer
    Dim points(0 To 47) As Double
    ' create the matrix of points
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 2: points(4) = 0: points(5) = 1
    points(6) = 4: points(7) = 0: points(8) = 0
    points(9) = 6: points(10) = 0: points(11) = 1
    points(12) = 0: points(13) = 2: points(14) = 0
    points(15) = 2: points(16) = 2: points(17) = 1
    points(18) = 4: points(19) = 2: points(20) = 0
    points(21) = 6: points(22) = 2: points(23) = 1
    points(24) = 0: points(25) = 4: points(26) = 0
    points(27) = 2: points(28) = 4: points(29) = 1
    points(30) = 4: points(31) = 4: points(32) = 0
    points(33) = 6: points(34) = 4: points(35) = 0
    points(36) = 0: points(37) = 6: points(38) = 0
    points(39) = 2: points(40) = 6: points(41) = 1
    points(42) = 4: points(43) = 6: points(44) = 0
    points(45) = 6: points(46) = 6: points(47) = 0
    mSize = 4: nSize = 4
    ' creates a 3Dmesh in model space
    Set meshObj = ThisDrawing.ModelSpace. _
 Add3DMesh(mSize, nSize, points)
    ' Change the viewing direction of the viewport
    ' to better see the cylinder
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1
    NewDirection(1) = -1
    NewDirection(2) = 1
    ThisDrawing.ActiveViewport.Direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
GMT+8, 2026-10-31 10:38
