关于浏览菜单项的属性 (VBA/ActiveX)
使用对象的属性,可以控制对象在对象上的显示和行为方式。PopupMenuItemPopupMenu 所有菜单项共享以下属性:
启用和禁用菜单项此示例创建一个名为“TestMenu”的新菜单,并插入两个菜单项。然后使用该属性禁用第二个菜单项,并且该菜单将显示在菜单栏上。Enable Sub Ch6_DisableMenuItem()
Dim currMenuGroup As AcadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add two menu items and a menu separator to the new menu
Dim MenuEnable As AcadPopupMenuItem
Dim MenuDisable As AcadPopupMenuItem
Dim MenuSeparator As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) + Chr(3) + "_open "
Set MenuEnable = newMenu.AddMenuItem _
(newMenu.count + 1, "OpenEnabled", openMacro)
Set MenuSeparator = newMenu.AddSeparator("")
Set MenuDisable = newMenu.AddMenuItem _
(newMenu.count + 1, "OpenDisabled", openMacro)
' Disable the second menu item
MenuDisable.Enable = False
' Display the menu on the menu bar
newMenu.InsertInMenuBar _
(ThisDrawing.Application.menuBar.count + 1)
相关概念 |
GMT+8, 2026-11-22 14:33
