关于 AutoCAD 如何保存图层设置 (VBA/ActiveX)
AutoCAD 将图层设置信息保存在图形集合的扩展字典中。Layers 首次在图形中保存图层设置时,AutoCAD 将执行以下操作:
每次在图形中保存另一个图层设置时,AutoCAD 都会创建另一个对象来描述所保存的设置,并将其存储在 ACAD_LAYERSTATE 字典中。下图说明了该过程。XRecordXRecord ![]() 在使用 ActiveX 处理图层设置时,您不需要(也不应尝试)解释。使用对象的功能访问保存的图层设置。XRecordsLayerStateManager 列出图形中保存的图层设置如果已在当前图形中保存了图层设置,则以下代码将列出所有已保存的图层设置的名称: Sub Ch4_ListStates()
On Error Resume Next
Dim oLSMDict As AcadDictionary
Dim XRec As Object
Dim layerstateNames As String
layerstateNames = ""
' Get the ACAD_LAYERSTATES dictionary, which is in the
' extension dictionary in the Layers object.
Set oLSMDict = ThisDrawing.Layers.GetExtensionDictionary.Item("ACAD_LAYERSTATES")
' List the name of each saved layer setting. Settings are
' stored as XRecords in the dictionary.
For Each XRec In oLSMDict
layerstateNames = layerstateNames + XRec.Name + vbCrLf
Next XRec
MsgBox "The saved layer settings in this drawing are: " + vbCrLf + layerstateNames
GMT+8, 2026-10-17 21:01
