关于使另一个平铺视口成为当前视口 (VBA/ActiveX)
2024-5-18 18:31| 发布者: admin| 查看: 898| 评论: 0|原作者: admin|来自: AutoCAD
在当前视口中输入点并选择对象。若要使视口成为当前视口,请使用该属性。ActiveViewport
您可以循环访问现有视口以查找特定视口。为此,请首先使用该属性确定所需视口所在的视口配置的名称。此外,如果视口配置已拆分,则可以通过 和 属性来标识配置上的每个单独视口。NameLowerLeftCornerUpperRightCorner
and 属性表示视口在显示器上的图形位置。这些属性定义如下(以四向拆分为例):LowerLeftCornerUpperRightCorner
在此示例中:
  • 视口 1: = (0, .5), = (.5, 1)LowerLeftCornerUpperRightCorner
  • 视口 2:= (.5, .5), = (1, 1)LowerLeftCornerUpperRightCorner
  • 视口 3:= (0, 0), = (.5, .5)LowerLeftCornerUpperRightCorner
  • 视口 4:= (.5, 0), = (1, .5)LowerLeftCornerUpperRightCorner
拆分视口,然后遍历窗口
此示例将视口拆分为四个窗口。然后,它会循环访问图形中的所有视口,并显示视口名称以及每个视口的左下角和右上角。
Sub Ch3_IteratingViewportWindows()
  ' Create a new viewport and make it active
  Dim vportObj As AcadViewport
  Set vportObj = ThisDrawing.Viewports.Add("TEST_VIEWPORT")
  ThisDrawing.ActiveViewport = vportObj
  ' Split vport into 4 windows
  vportObj.Split acViewport4
  ' Iterate through the viewports,
  ' highlighting each viewport and displaying
  ' the upper right and lower left corners
  ' for each.
  Dim vport As AcadViewport
  Dim LLCorner As Variant
  Dim URCorner As Variant
  For Each vport In ThisDrawing.Viewports
    LLCorner = vport.LowerLeftCorner
    URCorner = vport.UpperRightCorner
    MsgBox "Viewport: " & vport.Name & " is now active." & _
    vbCrLf & "Lower left corner: " & _
    LLCorner(0) & ", " & LLCorner(1) & vbCrLf & _
    "Upper right corner: " & _
    URCorner(0) & ", " & URCorner(1)
  Next vport
GMT+8, 2026-11-17 07:50
