AutoCAD 2007 API 历史记录参考 (ActiveX)
2024-5-18 18:30| 发布者: admin| 查看: 1280| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2007 和基于 AutoCAD 2007 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcEntityName (Changed)
        acDwfUnderlay = 46 (New)
        acDgnUnderlay = 47 (New)
AcViewportScale (Changed)
        acVp1_1 = 2 (New)
        acVp1_2 = 3 (New)
        acVp1_4 = 4 (New)
        acVp1_8 = 5 (New)
        acVp1_10 = 6 (New)
        acVp1_16 = 7 (New)
        acVp1_20 = 8 (New)
        acVp1_30 = 9 (New)
        acVp1_40 = 10 (New)
        acVp1_50 = 11 (New)
        acVp1_100 = 12 (New)
        acVp2_1 = 13 (New)
        acVp4_1 = 14 (New)
        acVp8_1 = 15 (New)
        acVp10_1 = 16 (New)
        acVp100_1 = 17 (New)
        acVp1_128in_1ft = 18 (New)
        acVp1_64in_1ft = 19 (New)
        acVp1_32in_1ft = 20 (New)
        acVp1_16in_1ft = 21 (New)
        acVp3_32in_1ft = 22 (New)
        acVp1_8in_1ft = 23 (New)
        acVp3_16in_1ft = 24 (New)
        acVp1_4in_1ft = 25 (New)
        acVp3_8in_1ft = 26 (New)
        acVp1_2in_1ft = 27 (New)
        acVp3_4in_1ft = 28 (New)
        acVp1in_1ft = 29 (New)
        acVp1and1_2in_1ft = 30 (New)
        acVp3in_1ft = 31 (New)
        acVp6in_1ft = 32 (New)
        acVp1ft_1ft = 33 (New)
AcSaveAsType (Changed)
        ac2007_dwg = 36 (New)
        ac2007_dxf = 37 (New)
        ac2007_Template = 38 (New)
        acNative = 36 (Changed)
AcValueDataType (New)
        acUnknownDataType = 0
        acLong = 1
        acDouble = 2
        acString = 4
        acDate = 8
        acPoint2d = 16
        acPoint3d = 32
        acObjectId = 64
        acBuffer = 128
        acResbuf = 256
        acGeneral = 512
AcValueUnitType (New)
        acUnitless = 0
        acUnitDistance = 1
        acUnitAngle = 2
        acUnitArea = 4
        acUnitVolume = 8
AcParseOption (New)
        acParseOptionNone = 0
        acSetDefaultFormat = 1
        acPreserveMtextFormat = 2
AcFormatOption (New)
        kFormatOptionNone = 0
        acForEditing = 1
        acForExpression = 2
        acUseMaximumPrecision = 4
        acIgnoreMtextFormat = 8
AcTableStyleOverrides (Changed)
        acTitleRowDataType = 24 (New)
        acHeaderRowDataType = 25 (New)
        acDataRowDataType = 26 (New)
        acCellDataType = 148 (New)
AcSectionState (New)
        acSectionStatePlane = 1
        acSectionStateBoundary = 2
        acSectionStateVolume = 4
AcSectionSubItem (New)
        acSectionSubItemkNone = 0
        acSectionSubItemSectionLine = 1
        acSectionSubItemSectionLineTop = 2
        acSectionSubItemSectionLineBottom = 4
        acSectionSubItemBackLine = 8
        acSectionSubItemBackLineTop = 16
        acSectionSubItemBackLineBottom = 32
        acSectionSubItemVerticalLineTop = 64
        acSectionSubItemVerticalLineBottom = 128
AcSectionType (New)
        acSectionTypeLiveSection = 1
        acSectionType2dSection = 2
        acSectionType3dSection = 4
AcSectionGeneration (New)
        acSectionGenerationSourceAllObjects = 1
        acSectionGenerationSourceSelectedObjects = 2
        acSectionGenerationDestinationNewBlock = 16
        acSectionGenerationDestinationReplaceBlock = 32
        acSectionGenerationDestinationFile = 64
AcHelixConstrainType (New)
        acTurnHeight = 0
        acTurns = 1
        acHeight = 2
AcShadowDisplayType (New)
        acCastsAndReceivesShadows = 0
        acCastsShadows = 1
        acReceivesShadows = 2
        acIgnoreShadows = 3
AcLoftedSurfaceNormalType (New)
        acRuled = 0
        acSmooth = 1
        acFirstNormal = 2
        acLastNormal = 3
        acEndsNormal = 4
        acAllNormal = 5
        acUseDraftAngles = 6
AcHelixTwistType (New)
        acCCW = 0
        acCW = 1
类
IAcadDatabase (Changed)
        SectionManager - Property (New)
        Materials - Property (New)
IAcadBlock (Changed)
        AddTable - Method (Moved from IAcadBlock2)
        Path - Property (Moved from IAcadBlock2)
        Comments - Property (Moved from IAcadBlock3)
        Units - Property (Moved from IAcadBlock3)
        Explodable - Property (Moved from IAcadBlock3)
        BlockScaling - Property (Moved from IAcadBlock3)
        IsDynamicBlock - Property (Moved from IAcadBlock3)
        AddDimArc - Method (Moved from IAcadBlock3)
        AddDimRadialLarge - Method (Moved from IAcadBlock3)
        AddSection - Method (New)
IAcadEntity (Changed)
        Material - Property (New)
IAcadAttribute (Changed)
        LockPosition - Property (Moved from IAcadAttribute2)
IAcadAttributeReference (Changed)
        LockPosition - Property (Moved from IAcadAttributeReference2)
IAcad3DSolid (Changed)
        SolidType - Property (New)
        Position - Property (New)
        History - Property (New)
        ShowHistory - Property (New)
IAcadDimAligned (Changed)
        DimensionLinetype - Property (New)
        ExtLine1Linetype - Property (New)
        ExtLine2Linetype - Property (New)
        ExtLineFixedLenSuppress - Property (New)
        ExtLineFixedLen - Property (New)
IAcadDimension (Changed)
        TextFill - Property (New)
        TextFillColor - Property (New)
IAcadDimAngular (Changed)
IAcadDimDiametric (Changed)
IAcadDimRotated (Changed)
IAcadDimOrdinate (Changed)
IAcadDimRadial (Changed)
IAcadMText (Changed)
        BackgroundFill - Property (Moved from IAcadMText2)
        FieldCode - Method (Moved from IAcadMText2)
IAcadText (Changed)
        FieldCode - Method (Moved from IAcadText2)
IAcadBlockReference (Changed)
        EffectiveName - Property (Moved from IAcadBlockReference2)
        IsDynamicBlock - Property (Moved from IAcadBlockReference2)
        GetDynamicBlockProperties - Method (Moved from IAcadBlockReference2)
        ResetBlock - Method (Moved from IAcadBlockReference2)
        ConvertToAnonymousBlock - Method (Moved from IAcadBlockReference2)
        ConvertToStaticBlock - Method (Moved from IAcadBlockReference2)
        XEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
        YEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
        ZEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
        InsUnits - Property (Moved from IAcadBlockReference2)
        InsUnitsFactor - Property (Moved from IAcadBlockReference2)
IAcadHatch (Changed)
        Area - Property (Moved from IAcadHatch2)
        Origin - Property (Moved from IAcadHatch2)
IAcadMLine (Changed)
        Justification - Property (Moved from IAcadMLine2)
        MLineScale - Property (Moved from IAcadMLine2)
IAcadDim3PointAngular (Changed)
IAcadExternalReference (Changed)
        XEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
        YEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
        ZEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
        InsUnits - Property (Moved from IAcadExternalReference2)
        InsUnitsFactor - Property (Moved from IAcadExternalReference2)
IAcadTable (Changed)
        RegenerateTableSuppressed - Property (Moved from IAcadTable2)
        GetDataType - Method (New)
        SetDataType - Method (New)
        GetFormat - Method (New)
        SetFormat - Method (New)
        FormatValue - Method (New)
        GetCellDataType - Method (New)
        SetCellDataType - Method (New)
        GetCellFormat - Method (New)
        SetCellFormat - Method (New)
        GetCellValue - Method (New)
        SetCellValue - Method (New)
        SetCellValueFromText - Method (New)
        ResetCellValue - Method (New)
IAcadDimArcLength (Changed)
        SymbolPosition - Property (New)
IAcadDimRadialLarge (Changed)
IAcadSection (New)
        Name - Property
        State - Property
        ViewingDirection - Property
        VerticalDirection - Property
        Normal - Property
        LiveSectionEnabled - Property
        IndicatorTransparency - Property
        IndicatorFillColor - Property
        Elevation - Property
        TopHeight - Property
        BottomHeight - Property
        NumVertices - Property
        Vertices - Property
        Coordinate - Property
        AddVertex - Method
        RemoveVertex - Method
        HitTest - Method
        CreateJog - Method
        Settings - Property
        GenerateSectionGeometry - Method
IAcadSectionSettings (New)
        CurrentSectionType - Property
        GetSectionTypeSettings - Method
IAcadSectionTypeSettings (New)
        GenerationOptions - Property
        SourceObjects - Property
        DestinationBlock - Property
        DestinationFile - Property
        IntersectionBoundaryColor - Property
        IntersectionBoundaryLayer - Property
        IntersectionBoundaryLinetype - Property
        IntersectionBoundaryLinetypeScale - Property
        IntersectionBoundaryPlotStyleName - Property
        IntersectionBoundaryLineweight - Property
        IntersectionBoundaryDivisionLines - Property
        IntersectionFillVisible - Property
        IntersectionFillHatchPatternType - Property
        IntersectionFillHatchPatternName - Property
        IntersectionFillHatchAngle - Property
        IntersectionFillHatchScale - Property
        IntersectionFillHatchSpacing - Property
        IntersectionFillColor - Property
        IntersectionFillLayer - Property
        IntersectionFillLinetype - Property
        IntersectionFillLinetypeScale - Property
        IntersectionFillPlotStyleName - Property
        IntersectionFillLineweight - Property
        IntersectionFillFaceTransparency - Property
        BackgroundLinesVisible - Property
        BackgroundLinesHiddenLine - Property
        BackgroundLinesColor - Property
        BackgroundLinesLayer - Property
        BackgroundLinesLinetype - Property
        BackgroundLinesLinetypeScale - Property
        BackgroundLinesPlotStyleName - Property
        BackgroundLinesLineweight - Property
        ForegroundLinesVisible - Property
        ForegroundLinesHiddenLine - Property
        ForegroundLinesColor - Property
        ForegroundLinesLayer - Property
        ForegroundLinesLinetype - Property
        ForegroundLinesLinetypeScale - Property
        ForegroundLinesPlotStyleName - Property
        ForegroundLinesLineweight - Property
        ForegroundLinesFaceTransparency - Property
        ForegroundLinesEdgeTransparency - Property
        CurveTangencyLinesVisible - Property
        CurveTangencyLinesColor - Property
        CurveTangencyLinesLayer - Property
        CurveTangencyLinesLinetype - Property
        CurveTangencyLinesLinetypeScale - Property
        CurveTangencyLinesPlotStyleName - Property
        CurveTangencyLinesLineweight - Property
IAcadPViewport (Changed)
        VisualStyle - Property (New)
        ModelView - Property (Moved from IAcadPViewport2)
        SheetView - Property (Moved from IAcadPViewport2)
        LabelBlockId - Property (Moved from IAcadPViewport2)
        HasSheetView - Property (Moved from IAcadPViewport2)
        SyncModelView - Method (Moved from IAcadPViewport2)
IAcadView (Changed)
        CategoryName - Property (Moved from IAcadView2)
        LayoutId - Property (Moved from IAcadView2)
        LayerState - Property (Moved from IAcadView2)
        HasVpAssociation - Property (Moved from IAcadView2)
IAcadGroup (Changed)
IAcadLayers (Changed)
        GenerateUsageData - Method (Moved from IAcadLayers2)
IAcadLayer (Changed)
        Description - Property (Moved from IAcadLayer2)
        Used - Property (Moved from IAcadLayer2)
IAcadSectionManager (New)
        Item - Method
        Count - Property
        GetLiveSection - Method
        GetUniqueSectionName - Method
IAcadMaterials (New)
        Item - Method
        Count - Property
        Add - Method
IAcadMaterial (New)
        Name - Property
IAcadTableStyle (Changed)
IAcadShadowDisplay (New)
        ShadowDisplay - Property
        EnableShadowDisplay - Property
IAcadMInsertBlock (Changed)
        EffectiveName - Property (Moved from IAcadMInsertBlock2)
        IsDynamicBlock - Property (Moved from IAcadMInsertBlock2)
        GetDynamicBlockProperties - Method (Moved from IAcadMInsertBlock2)
        ResetBlock - Method (Moved from IAcadMInsertBlock2)
        ConvertToAnonymousBlock - Method (Moved from IAcadMInsertBlock2)
        ConvertToStaticBlock - Method (Moved from IAcadMInsertBlock2)
        XEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
        YEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
        ZEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
        InsUnits - Property (Moved from IAcadMInsertBlock2)
        InsUnitsFactor - Property (Moved from IAcadMInsertBlock2)
IAcadHelix (New)
        Position - Property
        Constrain - Property
        Height - Property
        Turns - Property
        TurnHeight - Property
        BaseRadius - Property
        TopRadius - Property
        Twist - Property
        TurnSlope - Property
        TotalLength - Property
IAcadSurface (New)
        SurfaceType - Property
        UIsolineDensity - Property
        VIsolineDensity - Property
IAcadPlaneSurface (New)
IAcadExtrudedSurface (New)
        Height - Property
        TaperAngle - Property
IAcadRevolvedSurface (New)
        RevolutionAngle - Property
        AxisPosition - Property
        AxisDirection - Property
IAcadSweptSurface (New)
        ProfileRotation - Property
        Bank - Property
        Twist - Property
        scale - Property
        Length - Property
IAcadLoftedSurface (New)
        NumCrossSections - Property
        NumGuidePaths - Property
        SurfaceNormals - Property
        StartDraftAngle - Property
        StartDraftMagnitude - Property
        EndDraftAngle - Property
        EndDraftMagnitude - Property
        Closed - Property
IAcadUnderlay (New)
        Contrast - Property
        Fade - Property
        Position - Property
        Rotation - Property
        Width - Property
        Height - Property
        UnderlayName - Property
        ItemName - Property
        Monochrome - Property
        AdjustForBackground - Property
        ClipBoundary - Method
        File - Property
        UnderlayVisibility - Property
        ClippingEnabled - Property
IAcadSubEntity (New)
        OnModified - Event
        ObjectName - Property
        color - Property
        Layer - Property
        Linetype - Property
        Hyperlinks - Property
IAcadSubEntSolidFace (New)
        Material - Property
IAcadSubEntSolidEdge (New)
IAcadSubEntSolidVertex (New)
IAcadSubEntSolidNode (New)
IAcadModelSpace (Changed)
        AddTable - Method (Moved from IAcadModelSpace2)
        AddDimArc - Method (Moved from IAcadModelSpace3)
        AddDimRadialLarge - Method (Moved from IAcadModelSpace3)
IAcadPaperSpace (Changed)
        AddTable - Method (Moved from IAcadPaperSpace2)
        AddDimArc - Method (Moved from IAcadPaperSpace3)
        AddDimRadialLarge - Method (Moved from IAcadPaperSpace3)
IAcadDocument (Changed)
        ActiveMaterial - Property (New)
IAcadPreferencesFiles (Changed)
        EnterpriseMenuFile - Property (New)
        CustomIconPath - Property (New)
        QNewTemplateFile - Property (Moved from IAcadPreferencesFiles2)
        PlotLogFilePath - Property (Moved from IAcadPreferencesFiles2)
        PageSetupOverridesTemplateFile - Property (Moved from IAcadPreferencesFiles2)
IAcadPreferencesOutput (Changed)
        ContinuousPlotLog - Property (Moved from IAcadPreferencesOutput2)
        AutomaticPlotLog - Property (Moved from IAcadPreferencesOutput2)
        DefaultPlotToFilePath - Property (Moved from IAcadPreferencesOutput2)
IAcadUtility (Changed)
        SendModelessOperationStart - Property (Moved from IAcadUtility2)
以下类已删除/与其父类合并:
IAcadLayer2 (Removed - Moved to IAcadLayer)
IAcadView2 (Removed - Moved to IAcadView)
IAcadLayers2 (Removed - Moved to IAcadLayers)
IAcadAttribute2 (Removed - Moved to IAcadAttribute)
IAcadAttributeReference2 (Removed - Moved to IAcadAttributeReference)
IAcadBlockReference2 (Removed - Moved to IAcadBlockReference)
IAcadHatch2 (Removed - Moved to IAcadHatch)
IAcadMText2 (Removed - Moved to IAcadMText)
IAcadText2 (Removed - Moved to IAcadText)
IAcadPViewport2 (Removed - Moved to IAcadPViewport)
IAcadMInsertBlock2 (Removed - Moved to IAcadMInsertBlock)
IAcadMLine2 (Removed - Moved to IAcadMLine)
IAcadExternalReference2 (Removed - Moved to IAcadExternalReference)
IAcadTable2 (Removed - Moved to IAcadTable)
IAcadBlock2 (Removed - Moved to IAcadBlock)
IAcadBlock3 (Removed - Moved to IAcadBlock)
IAcadModelSpace2 (Removed - Moved to IAcadModelSpace)
IAcadModelSpace3 (Removed - Moved to IAcadModelSpace)
IAcadPaperSpace2 (Removed - Moved to IAcadPaperSpace)
IAcadPaperSpace3 (Removed - Moved to IAcadPaperSpace)
IAcadPreferencesFiles2 (Removed - Moved to IAcadPreferencesFiles)
IAcadPreferencesOutput2 (Removed - Moved to IAcadPreferencesOutput)
IAcadUtility2 (Removed - Moved to IAcadUtility)
GMT+8, 2026-12-1 00:09
