AutoCAD 2017 API 历史记录参考 (ActiveX)
2024-5-18 18:30| 发布者: admin| 查看: 1109| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2017 和基于 AutoCAD 2017 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcInsertUnits (Changed)
        acInsertUnitsUSSurveyFeet = 21 (New)
        acInsertUnitsUSSurveyInch = 22 (New)
        acInsertUnitsUSSurveyYard = 23 (New)
        acInsertUnitsUSSurveyMile = 24 (New)
类
AcadAcCmColor
        Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcCmColor.21.
AcadApplication
        Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.Application.21.
        ProgID AutoCAD.Application.20.1 is now obsolete.
AcadLayerStateManager
        Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcadLayerStateManager.21.
AcadSecurityParams
        Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.SecurityParams.21.
IAcadShadowDisplay (Obsolete)
        EnableShadowDisplay - Property (Obsolete)
GMT+8, 2026-11-29 11:06
