dumpallproperties (AutoLISP)
2024-5-18 18:29| 发布者: admin| 查看: 765| 评论: 0|原作者: admin|来自: AutoCAD
检索实体支持的属性
支持的平台:Windows 和 Mac OS
(dumpallproperties ename [context])
ename(英语:ename)
类型:Ename(实体名称)
被查询的实体的名称。ename 可以引用图形或非图形实体。
上下文
类型:整数
预期值为 0 或 1,未提供值时默认值为 0。当提供 1 作为上下文时,某些属性值(如 Position、Normal 和 StartPoint)将从单个值提升为单独的 X、Y 和 Z 值。
例如,以下内容首先将 StartPoint 显示为未升级,然后显示为已升级:
  • 未提升,上下文 = 0
    StartPoint (type: AcGePoint3d)  (LocalName: StartPoint) = 6.250000   8.750000  0.000000
  • 已升级,上下文 = 1
    StartPoint/X (type: double)  (LocalName: Start X) = 6.250000
    StartPoint/Y (type: double)  (LocalName: Start Y) = 8.750000
    StartPoint/Z (type: double)  (LocalName: Start Z) = 0.000000
返回值
类型:零
nil由函数返回,而属性及其当前值将输出到命令行历史记录。
下面的示例演示如何列出线条对象的可用属性,并将属性 Delta、EndPoint、Normal 和 StartPoint 提升为单个值。
Command: (setq e1 (car (entsel "\nSelect a line: ")))
Select a line:
<Entity name: 10e2e4b20>
Command: (dumpAllProperties e1 1)
Begin dumping object (class: AcDbLine)
Angle (type: double)  (RO)  (LocalName: Angle) = 5.159347
Annotative (type: bool)  (LocalName: Annotative) = Failed to get value to get value
Area (type: double)  (RO)  (LocalName: Area) = 0.000000
BlockId (type: AcDbObjectId)  (RO) = Ix
CastShadows (type: bool) = 0
ClassName (type: AcString)  (RO) =
Closed (type: bool)  (RO)  (LocalName: Closed) = Failed to get value
CollisionType (type: AcDb::CollisionType)  (RO) = 1
Color (type: AcCmColor)  (LocalName: Color) = BYLAYER
Delta/X (type: double)  (RO)  (LocalName: Delta X) = 3.028287
Delta/Y (type: double)  (RO)  (LocalName: Delta Y) = -6.318026
Delta/Z (type: double)  (RO)  (LocalName: Delta Z) = 0.000000
EndParam (type: double)  (RO) = 7.006281
EndPoint/X (type: double)  (LocalName: End X) = 23.249243
EndPoint/Y (type: double)  (LocalName: End Y) = 11.968958
EndPoint/Z (type: double)  (LocalName: End Z) = 0.000000
ExtensionDictionary (type: AcDbObjectId)  (RO) = Ix
Handle (type: AcDbHandle)  (RO) = 1b2
HasFields (type: bool)  (RO) = 0
HasSaveVersionOverride (type: bool) = 0
Hyperlinks (type: AcDbHyperlink*)
IsA (type: AcRxClass*)  (RO) = AcDbLine
IsAProxy (type: bool)  (RO) = 0
IsCancelling (type: bool)  (RO) = 0
IsEraseStatusToggled (type: bool)  (RO) = 0
IsErased (type: bool)  (RO) = 0
IsModified (type: bool)  (RO) = 0
IsModifiedGraphics (type: bool)  (RO) = 0
IsModifiedXData (type: bool)  (RO) = 0
IsNewObject (type: bool)  (RO) = 0
IsNotifyEnabled (type: bool)  (RO) = 0
IsNotifying (type: bool)  (RO) = 0
IsObjectIdsInFlux (type: bool)  (RO) = 0
IsPeriodic (type: bool)  (RO) = 0
IsPersistent (type: bool)  (RO) = 1
IsPlanar (type: bool)  (RO) = 1
IsReadEnabled (type: bool)  (RO) = 1
IsReallyClosing (type: bool)  (RO) = 1
IsTransactionResident (type: bool)  (RO) = 0
IsUndoing (type: bool)  (RO) = 0
IsWriteEnabled (type: bool)  (RO) = 0
LayerId (type: AcDbObjectId)  (LocalName: Layer) = Ix
Length (type: double)  (RO)  (LocalName: Length) = 7.006281
LineWeight (type: AcDb::LineWeight)  (LocalName: Lineweight) = -1
LinetypeId (type: AcDbObjectId)  (LocalName: Linetype) = Ix
LinetypeScale (type: double)  (LocalName: Linetype scale) = 1.000000
LocalizedName (type: AcString)  (RO) = Line
MaterialId (type: AcDbObjectId)  (LocalName: Material) = Ix
MergeStyle (type: AcDb::DuplicateRecordCloning)  (RO) = 1
Normal/X (type: double) = 0.000000
Normal/Y (type: double) = 0.000000
Normal/Z (type: double) = 1.000000
ObjectId (type: AcDbObjectId)  (RO) = Ix
OwnerId (type: AcDbObjectId)  (RO) = Ix
PlotStyleName (type: AcString)  (LocalName: Plot style) = ByLayer
ReceiveShadows (type: bool) = 0 Failed to get value
StartParam (type: double)  (RO) = 0.000000
StartPoint/X (type: double)  (LocalName: Start X) = 20.220956
StartPoint/Y (type: double)  (LocalName: Start Y) = 18.286984
Thickness (type: double)  (LocalName: Thickness) = 0.000000
Transparency (type: AcCmTransparency)  (LocalName: Transparency) = 0
Visible (type: AcDb::Visibility) = 0
End object dump
GMT+8, 2026-10-17 05:11
