更新属性选项板同步的命令
调整命令处理程序以进行同步涉及对命令的 AutoCAD 注册及其执行代码的更改。 更新“属性”选项板同步的命令处理程序
acedRegCmds->addCommand("SQUARE_COMMANDS", "ASDKADDSQUARE",
"ADDSQ",
ACRX_CMD_MODAL | ACRX_CMD_INTERRUPTIBLE,
addSquare);
在已注册的 AutoCAD 命令的处理程序代码中,调用全局函数。此调用应在命令提示用户输入之前进行。acedSetIUnknownForCurrentCommand() 在出现提示时,轮询所有输入函数以获取返回值。RTMODELESS 如果返回,则放弃当前输入请求并继续执行下一个命令步骤。此调用是在同步的命令处理程序中进行的。RTMODELESS 在调用该函数之前,必须创建 COM 对象包装器和 COM 命令包装器的实例,然后通过连接点将两者关联起来。如果要将对象添加到 ,则通过调用 COM 对象包装器的函数实现来创建基础对象。使用返回的指针,可以调用函数的 COM 包装实现。acedSetIUnknownForCurrentCommand()AcDbDatabaseAcDbEntityIAcadBaseObject2Impl::CreateObject()IAcadBaseObject2::AddToDb() 下面是 com\AsdkSquareWrapper_dg\Square\squareui.cpp 的命令处理程序函数:addSquare() void addSquare()
CComPtr<IAsdkSquareWrapper> pSquare;
CComQIPtr<IAcadBaseObject2> pSquareBase;
CComQIPtr<IConnectionPointContainer> pConnectionPts;
CComPtr<IConnectionPoint> pConnection;
CComObject<CAsdkSquareCmd> *pSquareCmdObj;
CComPtr<IUnknown> pSquareCmd;
DWORD connectionId = 0;
HRESULT hr = S_OK;
try {
// Create the wrapper object which we will place into OPM
// to display the square's properties
if (FAILED(hr =
pSquare.CoCreateInstance(CLSID_AsdkSquareWrapper)))
throw hr;
pSquareBase = pSquare;
// Create the underlying square object
if (FAILED(hr = pSquareBase->CreateObject()))
throw hr;
// Create the square modification listener which we use to
// synchronize changes in OPM and the command line
if (FAILED(hr = CComObject<CAsdkSquareCmd>::CreateInstance(
&pSquareCmdObj)))
throw hr;
pSquareCmdObj->QueryInterface(IID_IUnknown,
(void **)&pSquareCmd);
// Attach the square modification listener to the wrapper
pConnectionPts = pSquare;
if (!pConnectionPts)
throw E_POINTER;
if (FAILED(hr = pConnectionPts->FindConnectionPoint
(IID_IPropertyNotifySink, &pConnection)))
throw hr;
if (FAILED(hr = pConnection->Advise(pSquareCmd,
&connectionId)))
throw hr;
catch (HRESULT) {
acutPrintf("\n Error initializing command.");
return;
// Set the square object up for OPM
acedSetIUnknownForCurrentCommand(pSquare);
// Now process the command line input by
// looping for all required parameters
ads_point pt0, pt1;
ads_real size = 0.0;
struct resbuf UCS, WCS;
int retval;
WCS.restype = RTSHORT;
WCS.resval.rint = 0;
UCS.restype = RTSHORT;
UCS.resval.rint = 1;
while (true) {
if (!pSquareCmdObj->GotCenterPoint())
retval = acedGetPoint(NULL, "\nPick a point for the
center: ", pt0);
if (retval == RTCAN)
break;
else if (retval != RTNORM)
continue;
acedTrans(pt0, &UCS, &WCS, 0, pt1);
AcAxPoint3d pnt3d(pt1[X], pt1[Y], pt1[Z]);
pSquare->put_CenterPoint(*(pnt3d.asVariantPtr()));
if (!pSquareCmdObj->GotSquareSize())
retval = acedGetDist(pt0, "\nPick the square size : ",
&size);
break;
continue;
pSquare->put_SquareSize(size);
AcDbObjectId squareId;
if (FAILED(hr = pSquareBase->AddToDb(squareId,
curDoc()->database()->currentSpaceId())))
acutPrintf("\n Error appending object to database.");
break;
break;
// Unadvise the square modified listener
pConnection->Unadvise(connectionId);
return;
父主题: |
GMT+8, 2026-11-12 12:36
