剪辑边界示例
在以下示例中,在绘制任何内容之前,剪辑边界被推送到剪辑边界堆栈上,并在此对象的绘制完成后再次弹出: Adesk::Boolean
MyObject::subWorldDraw(AcGiWorldDraw* pDraw)
AcGiWorldGeometry * pGeom = &pDraw->geometry();
pGeom->pushModelTransform(myTransform());
AcGiClipBoundary cb;
cb.m_bDrawBoundary = true;
cb.m_vNormal = AcGeVector3d::kZAxis;
cb.m_ptPoint = AcGePoint3d::kOrigin;
// Two points treated as a rectangle, three creates a triangle
cb.m_aptPoints.append(AcGePoint2d(0,0));
cb.m_aptPoints.append(AcGePoint2d(5,5));
// We are clipping in our own space
cb.m_xToClipSpace.setToIdentity();
cb.m_xInverseBlockRefXForm = myTransform().inverse();
// No Z clipping
cb.m_bClippingBack = cb.m_bClippingFront = false;
cb.m_dFrontClipZ = cb.m_dBackClipZ = 0.;
Adesk::Boolean bPopClipBoundary = pGeom->pushClipBoundary(&cb);
// Draw something
pGeom->circle(...);
pGeom->popModelTransform();
if(bPopClipBoundary){ pGeom->popClipBoundary(); }
return true; // world-only
由于此裁剪是一项复杂的操作,因此某些 AcGi 实现可能不完全支持它。在这种情况下,AcGi 实现可能会从 返回 false,并且不应调用 。pushClipBoundary()popClipBoundary() 父主题: |
GMT+8, 2026-11-12 12:50
