使用 AcGi 的示例
以下示例说明了如何使用 AcGi。首先,它保存颜色、线型和图层的当前实体属性值。然后,它将子实体特征颜色值更改为蓝色,并绘制一条三点折线。接下来,它将子实体特征颜色值更改为当前图层颜色,将线型值更改为 ,并绘制一条 xline。DASHDOT 示例代码包括两个函数 和 ,它们允许您从字符串中获取线型或图层的 ID。getLinetypeFromString()getLayerIdFromString() 注意:在实践中,这些函数可能太慢而无法在 中使用,应直接存储和使用对象 ID。worldDraw()
static Acad::ErrorStatus getLinetypeIdFromString(const TCHAR* str, AcDbObjectId& id); static Acad::ErrorStatus getLayerIdFromString(const TCHAR* str, AcDbObjectId& id); Adesk::Boolean
AsdkTraitsSamp::subWorldDraw(AcGiWorldDraw* pW)
// At this point, the current property traits are
// the entity's property traits. If the current
// property traits are changed and you want to
// reapply the entity's property traits, this is
// the place to save them.
Adesk::UInt16 entity_color
= pW->subEntityTraits().color();
AcDbObjectId entity_linetype
= pW->subEntityTraits().lineTypeId();
AcDbObjectId entity_layer
= pW->subEntityTraits().layerId();
// Override the current color and make it blue.
pW->subEntityTraits().setColor(kBlue);
// Draw a blue 3-point polyline.
int num_pts = 3;
AcGePoint3d *pVerts = new AcGePoint3d[num_pts];
pVerts[0] = AcGePoint3d(0.0, 0.0, 0);
pVerts[1] = AcGePoint3d(1.0, 0.0, 0);
pVerts[2] = AcGePoint3d(1.0, 1.0, 0);
pW->geometry().polyline(num_pts, pVerts);
// Force the current color to use current layer's color.
pW->subEntityTraits().setColor(kColorByLayer);
// Force current line type to "DASHDOT". If
// "DASHDOT" is not loaded, the current line
// type will still be in effect.
AcDbObjectId dashdotId;
if (getLinetypeIdFromString(_T("DASHDOT"), dashdotId)
== Acad::eOk)
pW->subEntityTraits().setLineType(dashdotId);
// Force current layer to "MY_LAYER". If
// "MY_LAYER" is not loaded, the current layer
// will still be in effect.
AcDbObjectId layerId;
if (getLayerIdFromString(_T("MY_LAYER"), layerId)
== Acad::eOk)
pW->subEntityTraits().setLayer(layerId);
// Draw a dashdot'd xline in "MY_LAYER"'s color.
pW->geometry().xline(pVerts[0], pVerts[2]);
delete [] pVerts;
return Adesk::kTrue;
// A useful function that gets the linetype ID from the
// linetype's name -- must be in upper case.
Acad::ErrorStatus err;
// Get the table of currently loaded linetypes.
AcDbLinetypeTable *pLinetypeTable;
err = acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pLinetypeTable, AcDb::kForRead);
if (err != Acad::eOk)
return err;
// Get the id of the linetype with the name that
// 'str' contains.
err = pLinetypeTable->getAt(str, id, Adesk::kTrue);
pLinetypeTable->close();
return err;
// A useful function that gets the layer ID from the
// layer's name -- must be in upper case.
// Get the table of currently loaded layers.
AcDbLayerTable *pLayerTable;
->getSymbolTable(pLayerTable, AcDb::kForRead);
return err;
// Get the ID of the layer with the name that 'str'
// contains.
err = pLayerTable->getAt(str, id, Adesk::kTrue);
pLayerTable->close();
return err;
父主题: |
GMT+8, 2026-11-14 15:12
