克隆来自不同所有者的对象
如果要克隆来自不同所有者的一组对象,则需要将对象 ID 集划分为每个所有者的单独组。(克隆的对象及其所有者应属于同一数据库。在本节的示例中,将要克隆的模型空间对象添加到 中,将要克隆的图纸空间对象添加到:objListMSobjListPS objListMS.append(objId); objListPS.append(objId); 然后,使用相同的 ID 映射调用该函数两次。必须使用单个 ID 映射进行所有克隆,才能正确完成参考翻译。在第一次调用时,该参数设置为 。在第二次(最后一次)调用时,默认为 :deepCloneObjects()deferXlationkTruedeepCloneObjects()deferXlationkFalse acdbHostApplicationServices()->workingDatabase()-> deepCloneObjects(mslist, modelSpaceId, idMap, Adesk::kTrue); acdbHostApplicationServices()->workingDatabase()-> deepCloneObjects(pslist, paperSpaceId, idMap); 此时,克隆结束,所有参考文献都已翻译。以下代码深度克隆属于不同所有者的对象:
void
cloneDiffOwnerObjects()
// Step 1: Obtain the set of objects to be cloned.
// For the two owners we'll use model space and
// paper space, so we must perform two acedSSGet() calls.
// calls.
acutPrintf("\nSelect entities to be cloned to"
" Model Space");
ads_name ssetMS;
acedSSGet(NULL, NULL, NULL, NULL, ssetMS);
long lengthMS;
acedSSLength(ssetMS, &lengthMS);
" Paper Space");
ads_name ssetPS;
if (acedSSGet(NULL, NULL, NULL, NULL, ssetPS)
!= RTNORM && lengthMS == 0)
acutPrintf("\nNothing selected");
return;
long lengthPS;
acedSSLength(ssetPS, &lengthPS);
// Step 2: Add obtained object IDs to the lists of
// objects to be cloned: one list for objects to
// be owned by model space and one for those to
// be owned by paper space.
AcDbObjectId ownerId = AcDbObjectId::kNull;
// For model space
AcDbObjectIdArray objListMS;
for (int i = 0; i < lengthMS; i++) {
ads_name ent;
acedSSName(ssetMS, i, ent);
AcDbObjectId objId;
acdbGetObjectId(objId, ent);
// Check to be sure this has the same owner as the first
// object.
AcDbObject *pObj;
acdbOpenObject(pObj, objId, AcDb::kForRead);
if (pObj->ownerId() == ownerId)
else if (i == 0) {
ownerId = pObj->ownerId();
pObj->close();
acedSSFree(ssetMS);
// For paper space
AcDbObjectIdArray objListPS;
for (i = 0; i < lengthPS; i++) {
ads_name ent;
acedSSName(ssetPS, i, ent);
AcDbObjectId objId;
// object.
AcDbObject *pObj;
else if (i == 0) {
pObj->close();
acedSSFree(ssetPS);
// Step 3: Get the object ID of the desired owners for
// the cloned objects. We're using model space and
// paper space for this example.
AcDbBlockTable *pBlockTable;
->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbObjectId modelSpaceId, paperSpaceId;
pBlockTable->getAt(ACDB_MODEL_SPACE, modelSpaceId);
pBlockTable->getAt(ACDB_PAPER_SPACE, paperSpaceId);
pBlockTable->close();
// Step 4: Create a new ID map.
AcDbIdMapping idMap;
// Step 5: Call deepCloneObjects().
->deepCloneObjects(objListMS, modelSpaceId, idMap,
Adesk::kTrue);
->deepCloneObjects(objListPS, paperSpaceId, idMap);
// Now we can go through the ID map and do whatever we'd
// like to the original and/or clone objects.
// For this example we'll print out the object IDs of
// the new objects resulting from the cloning process.
AcDbIdMappingIter iter(idMap);
for (iter.start(); !iter.done(); iter.next()) {
AcDbIdPair idPair;
iter.getMap(idPair);
if (!idPair.isCloned())
continue;
acutPrintf("\nObjectId is: %Ld",
idPair.value().asOldId());
父主题: |
GMT+8, 2026-11-12 12:59
