典型的深度克隆操作
以下代码摘录显示了 的典型用法。AcDbDatabase::deepCloneObjects() 启动深度克隆操作
在此示例中,所有者对象 ID 是模型空间块表记录。该函数填充对象 ID 映射 ()。然后,应用程序可以使用特殊的迭代器对象 () 循环访问映射中包含的对象,并对这些对象执行其他操作,例如按特定矩阵转换每个对象。deepCloneObjects()idMapAcDbIdMappingIter 以下代码显示了deepCloneObjects(): void
cloneSameOwnerObjects()
// Step 1: Obtain the set of objects to be cloned.
ads_name sset;
if (acedSSGet(NULL, NULL, NULL, NULL, sset) != RTNORM) {
acutPrintf("\nNothing selected");
return;
// Step 2: Add obtained object IDs to list of objects
// to be cloned.
long length;
acedSSLength(sset, &length);
AcDbObjectIdArray objList;
AcDbObjectId ownerId = AcDbObjectId::kNull;
for (int i = 0; i < length; i++) {
ads_name ent;
acedSSName(sset, i, ent);
AcDbObjectId objId;
acdbGetObjectId(objId, ent);
// Check to be sure this has the same owner as the first
// object.
AcDbObject *pObj;
acdbOpenObject(pObj, objId, AcDb::kForRead);
if (pObj->ownerId() == ownerId)
objList.append(objId);
else if (i == 0) {
ownerId = pObj->ownerId();
pObj->close();
acedSSFree(sset);
// Step 3: Get the object ID of the desired owner for
// the cloned objects. We'll use model space for
// this example.
AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbObjectId modelSpaceId;
pBlockTable->getAt(ACDB_MODEL_SPACE, modelSpaceId);
pBlockTable->close();
// Step 4: Create a new ID map.
AcDbIdMapping idMap;
// Step 5: Call deepCloneObjects().
->deepCloneObjects(objList, modelSpaceId, idMap);
// Now we can go through the ID map and do whatever we'd
// like to the original and/or clone objects.
// For this example, we'll print out the object IDs of
// the new objects resulting from the cloning process.
AcDbIdMappingIter iter(idMap);
for (iter.start(); !iter.done(); iter.next()) {
AcDbIdPair idPair;
iter.getMap(idPair);
if (!idPair.isCloned())
continue;
acutPrintf("\nObjectId is: %Ld",
idPair.value().asOldId());
父主题: |
GMT+8, 2026-11-13 13:32
