变换函数
2024-5-18 18:26| 发布者: admin| 查看: 858| 评论: 0|原作者: admin|来自: AutoCAD
变换函数
该类提供两个转换函数。该函数将矩阵应用于实体。该函数使实体能够返回应用了转换的自身副本。AcDbEntitytransformBy()getTransformedCopy()
如果实体是均匀缩放和正交的,则函数的默认实现将克隆该实体,然后在克隆的实体上调用该函数。(使用该函数确定输入矩阵是否均匀缩放和正交。AcDbEntity::getTransformedCopy()transformBy()AcGeMatrix3d::isUniScaledOrtho()
若要修改默认行为,请重写自定义实体和函数,它们分别由 和 调用。subGetTransformedCopy()subTransformBy()getTransformedCopy()transformBy()
自定义类重写函数和函数。当不均匀缩放时,它将成为折线。AsdkPolysubTransformBy()subGetTransformedCopy()AsdkPoly
 Acad::ErrorStatus
 AsdkPoly::subTransformBy(const AcGeMatrix3d& xform)
     // If we're dragging, we aren't really going to change our
     // data, so we don't want to make an undo recording nor do
     // we really care if the object's open for write.
     if (mDragDataFlags & kCloneMeForDraggingCalled) {
         mDragDataFlags |= kUseDragCache;
         mDragPlaneNormal = mPlaneNormal;
         mDragElevation = mElevation;
         AcGeMatrix2d xform2d(xform.convertToLocal(mDragPlaneNormal,
          mDragElevation));
         mDragCenter = mCenter;
         mDragCenter.transformBy(xform2d);
         mDragStartPoint = mStartPoint;
         mDragStartPoint.transformBy(xform2d);
         mDragPlaneNormal.normalize();
     } else {
         assertWriteEnabled();
         AcGeMatrix2d xform2d(xform.convertToLocal(mPlaneNormal,
          mElevation));
         mCenter.transformBy(xform2d);
         mStartPoint.transformBy(xform2d);
         mPlaneNormal.normalize();
     return Acad::eOk;
 // Transform points and create a polyline out of them.
 Acad::ErrorStatus AsdkPoly::subGetTransformedCopy(
     const AcGeMatrix3d& mat,
     AcDbEntity*& ent) const
     assertReadEnabled();
     Acad::ErrorStatus es = Acad::eOk;
     AcGePoint3dArray vertexArray;
     if ((es = getVertices3d(vertexArray))
         != Acad::eOk)
         return es;
     for (int i = 0; i < vertexArray.length(); i++) {
         vertexArray[i].transformBy(mat);
     AcDbSpline *pSpline = NULL;
     if ((es = rx_makeSpline(vertexArray, pSpline))
         != Acad::eOk)
         return es;
     assert(pSpline != NULL);
     pSpline->setPropertiesFrom(this);
     ent = pSpline;
     return es;
GMT+8, 2026-11-14 14:17
