源文件
下面的代码显示了新类的实现:AsdkMyClass ACRX_DXF_DEFINE_MEMBERS(AsdkMyClass, AcDbObject,
AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent, 0,
ASDKMYCLASS, SAMP2);
// Gets the value of the integer data member.
Acad::ErrorStatus
AsdkMyClass::getData(Adesk::Int16& val)
// Tells AutoCAD a read operation is taking place.
assertReadEnabled();
val = mIntval;
return Acad::eOk;
// Sets the value of the integer data member.
Acad::ErrorStatus
AsdkMyClass::setData(Adesk::Int16 val)
// Triggers openedForModify notification.
assertWriteEnabled();
mIntval = val;
return Acad::eOk;
// Files data in from a DWG file.
Acad::ErrorStatus
AsdkMyClass::dwgInFields(AcDbDwgFiler* pFiler)
AcDbObject::dwgInFields(pFiler);
// For wblock filing we wrote out our owner as a hard
// pointer ID so now we need to read it in to keep things
// in sync.
if (pFiler->filerType() == AcDb::kWblockCloneFiler) {
AcDbHardPointerId id;
pFiler->readItem(&id);
pFiler->readItem(&mIntval);
return pFiler->filerStatus();
// Files data out to a DWG file.
Acad::ErrorStatus
AsdkMyClass::dwgOutFields(AcDbDwgFiler* pFiler) const
AcDbObject::dwgOutFields(pFiler);
// Since objects of this class will be in the Named
// Objects Dictionary tree and may be hard referenced
// by some other object, to support wblock we need to
// file out our owner as a hard pointer ID so that it
// will be added to the list of objects to be wblocked.
pFiler->writeHardPointerId((AcDbHardPointerId)ownerId());
pFiler->writeItem(mIntval);
// Files data in from a DXF file.
Acad::ErrorStatus
AsdkMyClass::dxfInFields(AcDbDxfFiler* pFiler)
Acad::ErrorStatus es;
if ((es = AcDbObject::dxfInFields(pFiler))
!= Acad::eOk)
return es;
// Check if we're at the right subclass getData marker.
if (!pFiler->atSubclassData("AsdkMyClass")) {
return Acad::eBadDxfSequence;
struct resbuf inbuf;
while (es == Acad::eOk) {
if ((es = pFiler->readItem(&inbuf)) == Acad::eOk) {
if (inbuf.restype == AcDb::kDxfInt16) {
mIntval = inbuf.resval.rint;
// Files data out to a DXF file.
Acad::ErrorStatus
AsdkMyClass::dxfOutFields(AcDbDxfFiler* pFiler) const
AcDbObject::dxfOutFields(pFiler);
pFiler->writeItem(AcDb::kDxfSubclass, "AsdkMyClass");
pFiler->writeItem(AcDb::kDxfInt16, mIntval);
// This function creates two objects of class AsdkMyClass.
// It fills them in with the integers 1 and 2, and then adds
// them to the dictionary associated with the key ASDK_DICT.
// If this dictionary doesn't exist, it is created and added
// to the named object dictionary.
void
createDictionary()
AcDbDictionary *pNamedobj;
acdbHostApplicationServices()->workingDatabase()->
getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
// Check to see if the dictionary we want to create is
// already present. If not, create it and add
// it to the named object dictionary.
AcDbDictionary *pDict;
if (pNamedobj->getAt("ASDK_DICT", (AcDbObject*&) pDict,
AcDb::kForWrite) == Acad::eKeyNotFound)
pDict = new AcDbDictionary;
AcDbObjectId DictId;
pNamedobj->setAt("ASDK_DICT", pDict, DictId);
pNamedobj->close();
if (pDict) {
// Create new objects to add to the new dictionary,
// add them, then close them.
AsdkMyClass *pObj1 = new AsdkMyClass(1);
AsdkMyClass *pObj2 = new AsdkMyClass(2);
AcDbObjectId rId1, rId2;
pDict->setAt("OBJ1", pObj1, rId1);
pDict->setAt("OBJ2", pObj2, rId2);
pObj1->close();
pObj2->close();
pDict->close();
// Opens the dictionary associated with the key ASDK_DICT
// and iterates through all its entries, printing out the
// integer data value in each entry.
void
iterateDictionary()
->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
// Get a pointer to the ASDK_DICT dictionary.
pNamedobj->getAt("ASDK_DICT", (AcDbObject*&)pDict,
AcDb::kForRead);
pNamedobj->close();
// Get an iterator for the ASDK_DICT dictionary.
AcDbDictionaryIterator* pDictIter= pDict->newIterator();
AsdkMyClass *pMyCl;
Adesk::Int16 val;
for (; !pDictIter->done(); pDictIter->next()) {
// Get the current record, open it for read, and
// print its data.
pDictIter->getObject((AcDbObject*&)pMyCl,
AcDb::kForRead);
pMyCl->getData(val);
pMyCl->close();
acutPrintf("\nintval is: %d", val);
delete pDictIter;
pDict->close();
// The initialization function called from the acrxEntryPoint()
// function during the kInitAppMsg case is used to add commands
// to the command stack and to add classes to the ACRX class
// hierarchy.
void
initApp()
acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS",
"ASDK_CREATE", "CREATE", ACRX_CMD_MODAL,
createDictionary);
"ASDK_ITERATE", "ITERATE", ACRX_CMD_MODAL,
iterateDictionary);
AsdkMyClass::rxInit();
acrxBuildClassHierarchy();
// The cleanup function called from the acrxEntryPoint() function
// during the kUnloadAppMsg case removes this application's
// command set from the command stack and removes this application's
// custom classes from the ACRX runtime class hierarchy.
void
unloadApp()
acedRegCmds->removeGroup("ASDK_DICTIONARY_COMMANDS");
// Remove the AsdkMyClass class from the ACRX runtime
// class hierarchy. If this is done while the database is
// still active, it should cause all objects of class
// AsdkMyClass to be turned into proxies.
deleteAcRxClass(AsdkMyClass::desc());
父主题: |
GMT+8, 2026-11-12 12:31
