具有顺序独立性的 dxfInFields() 的示例代码
以下是示例代码:AsdkPoly::dxfInFields() Acad::ErrorStatus
AsdkPoly::dxfInFields(AcDbDxfFiler* filer)
assertWriteEnabled();
Acad::ErrorStatus es = Acad::eOk;
resbuf rb;
if ((AcDbCurve::dxfInFields(filer) != Acad::eOk)
|| !filer->atSubclassData("AsdkPoly"))
return filer->filerStatus();
// Object Version
Adesk::Int16 version;
filer->readItem(&rb);
if (rb.restype != AcDb::kDxfInt16)
filer->pushBackItem();
filer->setError(Acad::eInvalidDxfCode,
"\nError: expected group code %d (version)",
AcDb::kDxfInt16);
version = rb.resval.rint;
if (version > VERSION)
return Acad::eMakeMeProxy;
AcGePoint3d cen3d,sp3d;
AcGePoint2d cen2d,sp2d;
long numSides;
AcDbObjectId textStyle;
double elevation;
Adesk::UInt32 fieldsFlags = 0;
char * pName = NULL;
AcGeVector3d planeNormal;
while ((es == Acad::eOk)
&& ((es = filer->readResBuf(&rb)) == Acad::eOk))
switch (rb.restype) {
case AcDb::kDxfXCoord:
if (version == 1)
cen3d = asPnt3d(rb.resval.rpoint);
else
cen2d = asPnt2d(rb.resval.rpoint);
fieldsFlags |= 0x1;
break;
case AcDb::kDxfXCoord + 1:
if (version == 1)
sp3d = asPnt3d(rb.resval.rpoint);
else
sp2d = asPnt2d(rb.resval.rpoint);
fieldsFlags |= 0x2;
break;
case AcDb::kDxfInt32:
numSides = rb.resval.rlong;
fieldsFlags |= 0x4;
break;
case AcDb::kDxfNormalX:
planeNormal = asVec3d(rb.resval.rpoint);
fieldsFlags |= 0x8;
break;
case AcDb::kDxfText:
acutUpdString(rb.resval.rstring,pName);
fieldsFlags |= 0x11;
break;
case AcDb::kDxfHardPointerId:
acdbGetObjectId(textStyle, rb.resval.rlname);
fieldsFlags |= 0x12;
break;
case AcDb::kDxfReal:
if (version == 2)
fieldsFlags |= 0x10;
elevation = rb.resval.rreal;
break;
//fall through intentional
default:
// An unrecognized group. Push it back so that
// the subclass can read it again.
es = Acad::eEndOfFile;
break;
// At this point, the es variable must contain eEndOfFile,
// either from readResBuf() or from pushbackBackItem(). If
// not, it indicates that an error happened and we should
// return immediately.
if (es != Acad::eEndOfFile)
return Acad::eInvalidResBuf;
// Now check to be sure all necessary group codes were
// present.
// Mandatory fields:
// - center
// - start point
// - normal
// - number of sides
// - elevation (if version > 1)
short required[] =
{AcDb::kDxfXCoord, AcDb::kDxfXCoord+1, AcDb::kDxfInt32,
AcDb::kDxfNormalX, AcDb::kDxfReal};
for (short i = 0; i < (version>1?4:3); i++) {
if (!fieldsFlags & 0x1) {
filer->setError(Acad::eMissingDxfField,
"\nMissing DXF group code: %d", 2, required[i]);
return Acad::eMissingDxfField;
} else
fieldsFlags >>= 1;
mPlaneNormal = planeNormal;
mNumSides = numSides;
mTextStyle = textStyle;
setName(pName);
acutDelString(pName);
if (version==1)
//convert data from old format
acdbWcs2Ecs(asDblArray(cen3d),asDblArray(cen3d),
asDblArray(planeNormal),Adesk::kFalse);
mCenter.set(cen3d.x,cen3d.y);
mElevation = cen3d.z;
acdbWcs2Ecs(asDblArray(sp3d),asDblArray(sp3d),
mStartPoint.set(sp3d.x,sp3d.y);
assert(mElevation == sp3d.z);
} else {
mCenter = cen2d;
mStartPoint = sp2d;
mElevation = elevation;
return es;
应用程序定义类的完整代码可以在 samples 目录中找到。AsdkPoly 父主题: |
GMT+8, 2026-11-13 13:51
