从绘图到文件
应用程序可以通过调用参数设置为 true 并包含完全限定的文件名来设置要打印到文件的文档。为了打印到文件,所选设备必须支持该功能。AcPlPlotEngine::beginDocument()bPlotToFilepFileName 以下代码显示了打印到文件,为清楚起见,省略了打印进度对话框代码: AcPlPlotEngine* pEngine = NULL;
if(Acad::eOk==AcPlPlotFactory::createPublishEngine(pEngine))
es = pEngine->beginPlot(pPlotProgDlg);
AcPlPlotPageInfo pageInfo;
AcPlPlotInfo plotInfo;
plotInfo.setLayout(layoutId);
AcPlPlotInfoValidator validator;
es = validator.validate(plotInfo);
const char *szDocName=acDocManager->curDocument()->fileName();
// Set bPlotToFile parameter to true.
es = pEngine->beginDocument(plotInfo, szDocName,
NULL, 1, true, m_csFilename);
es = pEngine->beginPage(pageInfo, plotInfo, true);
es = pEngine->beginGenerateGraphics();
es = pEngine->endGenerateGraphics();
es = pEngine->endPage();
es = pEngine->endDocument();
es = pEngine->endPlot();
// Destroy the engine.
pEngine->destroy();
pEngine = NULL;
else
// Ensure the engine is not already busy...
AfxMessageBox("Plot Engine is Busy...");
父主题: |
GMT+8, 2026-11-12 12:29
